pull key wait 10 seconds?
Old Jul 16, 2006 | 02:58 PM
tripod5's Avatar
tripod5
Default pull key wait 10 seconds?
First thing in the morning, before going to work i sat in the car and put my key in. It then said "pull key and wait 10 seconds". Does anyone know what this means? Thanks in advance. .......Bye the way, i did pull the key and waited 10 sec. and it ran fine.
Old Jul 16, 2006 | 03:15 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
see the sticky at the top about the ecl. get a clb and avoid all kinds of trouble.
Old Jul 16, 2006 | 05:42 PM
Miguels's Avatar
Miguels
Column lock...read sticky.
I had the same thing happen to me after the dealer did the recall...fortunate for me that the dealer removed the CL.
Old Jul 16, 2006 | 05:46 PM
EHS's Avatar
EHS
Well, yes, could be the column lock, could also be a simple computer reset.
Old Jul 16, 2006 | 05:54 PM
tripod5's Avatar
tripod5
I did take it in for the recall last year, and this is the first time it happened since. Its working fine now..........thanks for the replys
Old Jul 16, 2006 | 07:04 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
they need to make the sticky up top required reading when you join up
Old Jul 16, 2006 | 07:20 PM
Ricks-LS1's Avatar
Ricks-LS1
[QUOTE=tripod5]First thing in the morning, before going to work i sat in the car and put my key in. It then said "pull key and wait 10 seconds". Does anyone know what this means? Thanks in advance. .......Bye the way, i did pull the key and waited 10 sec. and it ran fine.[/QUOT
This happend to me yesterday right after I installed a CLB.
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
could be signs of something bad in your future .........like a k harness failure, or any number of things. fix it now or tow it later. well that is worst case anyway. hope it is just an isolated thing with your car but with all the problems that everyone seems to have with this if i had to do it all over again myself i would just get a bypass kit for $50 and forget about it.
Old Jul 18, 2006 | 10:47 AM
EHS's Avatar
EHS
Originally Posted by 2000FRCZ19
could be signs of something bad in your future .........like a k harness failure, or any number of things. fix it now or tow it later....
Like a very wise mechanic taught me, two rules, a long time ago:
1. Don't fix it if it ain't broke.
2. Don't go looking for something to fix.
Until the car exhibits other symptoms, this could just be a simple computer reset. I believe everyone has had experience with rebooting their computer, and the C5 has quite a number of them that might need to be rebooted.
Other good one's to fix are RFA comm failure codes. Tyr fixing these:
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
Same thing as the key pull message, service TC system message, AH failure message, TPS failure message -- absent other indications, do what it says, and leave it alone.
Old Jul 18, 2006 | 02:48 PM
patton's Avatar
patton
St. Jude Donor '09
happened to me twice 01 coupe both times it was raining and the key got wet . dried it on pants and good to go but it was scary
Old Jul 18, 2006 | 03:43 PM
SynistrC5's Avatar
SynistrC5
I thought I remembered seeing a post that said something about the phrase "pull key wait 10 seconds" was some bs for car isnt getting enough juice from the battery or something. Do a search this came up a few times in the spring when guys where bringing out their cars for the year.
To pull key wait 10 seconds?
