The main reason your car fights the ruts is due to the width of the front tires. Changing air pressure would have little or no affect on the problem. Tire construction might make a difference, though. I don't remember what it was like on my previous C5 with runflats, but on the Z06 is not bad so I imagine a non-runflat might have less of a problem. As far as alignment issues are concerned, camber has nothing to do with steering wander. Camber affects handling in turns. You put alot of negative camber in your front end and you'll wear your tires out real fast but it will stick like glue in a tight turn. Caster is what affects wander and steering return after a turn. It is also what is usually wrong if your car has a pull. You can increase caster slightly to combat the wander in ruts but it will also make your all-around steering effort feel heavier.
...Caster is what affects wander and steering return after a turn. It is also what is usually wrong if your car has a pull. You can increase caster slightly to combat the wander in ruts but it will also make your all-around steering effort feel heavier.
Excellent point!!!
I have the heaviest caster setting I can find on my C5 (I like firmer steering), and the ruts are a lot less noticable now.
With both you and EHS on this. Keep the caster at or very close to 7 degrees or so, and use non-runflat tires and you should almost completely eliminate "tracking".
Robert
The stock Goodyears on my '98 were "rut grabbers". Replaced them with Michelin Pilot Sport A/S ZPs, road force balanced. It's amazing how the ruts have vanished, even before doing a realignment. I run 30psi, cold.
