Engine Check Light Question
Old Jul 17, 2006 | 03:36 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Default Engine Check Light Question
I've had my LT's with Hi-Flo Cats on for several months and just got an engine check light the other day. Ran thru the DIC and got P0141 HO2S Heater Performance, which I cancelled and haven't seen again as yet. Am I correct in assuming that this is a rear O2 sensor problem as a result of the exhaust change?
Old Jul 17, 2006 | 04:23 PM
dougbfresh's Avatar
dougbfresh
I think your correct, the front ones heat up quickly being close to the engine, the rear ones use a heater to get up to the 600 or so degrees they need to be at quickly.
Old Jul 18, 2006 | 10:09 AM
sxeC7's Avatar
sxeC7
Anyone else have any thoughts on this?
Is this an O2 sensor failure problem or just that the sensor is not reading an adequate difference because of the Hi-Flo Cats?
Old Jul 18, 2006 | 07:26 PM
sxeC7's Avatar
sxeC7
ttt
To Engine Check Light Question
