CLB Install
Old Jul 17, 2006 | 07:12 PM
SSWEET's Avatar
SSWEET
Default CLB Install
If you had the GM recall K harness installed and you want to install the CLB...do you have to remove the K Harness before installing the CLB.
Old Jul 17, 2006 | 07:21 PM
FRCTony's Avatar
FRCTony
No.
Old Jul 17, 2006 | 08:22 PM
beltfed21's Avatar
beltfed21
I would think so, yes. But for now, I would just disconnect the column lock motor side of GM's harness, which would make it function more like the CLB (and would no longer require the column lock motor to function, which is a very good thing since a failure of this motor after the recall will still leave you stranded). Then if the harness K relay ever fails, you can then remove it completely and install the CLB (that you have been saving) in place of the harness k.
To CLB Install
