Need Help With Codes
Old Jul 17, 2006 | 09:46 PM
SSWEET's Avatar
SSWEET
Default Need Help With Codes
Been having some issues....these codes popped up in DIC all in History
Mode...
What do they actually mean?
40-BCM -Body Control Module
B2587 Column Lock/Unlock Drive (A)
B2592 Column Lock/Unlock Drive (B)
B0-RFA - Remote Function Actuation
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
Old Jul 31, 2006 | 10:38 PM
CPapin's Avatar
CPapin
I have the following codes too...
Any help out there? I have read that it could be a bad battery, but I have no memory or radio settings loss and the battery checked out fine on a load test. I've double checked the battery connections. Any help is appreciated!
Old Jul 31, 2006 | 10:52 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
what does the memory button light do when you push it.
Does it stay on steady or flash.
Does the seat move to memory and work properly.
Check fuse #5 engine compartment
Also check fuse #4 in passenger floor.
You have a blown fuse somewhere
Old Jul 31, 2006 | 10:55 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Mode...
Clear them see if they come back.
When you have a issue try all other controls like power windows ect.
report back.
U codes are common they are communication timeouts.
Old Aug 7, 2006 | 04:34 PM
CPapin's Avatar
CPapin
The only other code is P0327 (a knock sensor that needs to be replaced). I have cleared the codes but they return. I'll look into exactaly what the memory button does when I push it. All the memory functions work properly, except once when it failed to work, but I may not have locked the door w/ the FOB. I'll also double check the fuses when I get some time. I'll report back!
I haven't had time to look at the fuses yet, but the memory light is solid when active.
To Need Help With Codes
