Stupid....but I could use help
Jul 19, 2006 | 01:24 AM
So I how do I reset my oil life?
Jul 19, 2006 | 02:05 AM
Turn the key to the on position...but dont start it....press the gas pedal three times....your done.....
Jul 19, 2006 | 02:09 AM
Quote:
or, follow the procedure outlined in the owner's manual:
How to Reset the "Oil Life" indicator
After an oil change, you need to reset the oil life indicator so that you know when the next change is due. Here is how to do that:
1) Turn the ignition on, but make sure the engine is off.
2) Press the "Trip" button on the DIC so that it displays "OIL LIFE" percentage.
3) Press and hold the "Reset" button for two seconds. "OIL LIFE REMAIN 100%" should appear on the display.
