Digital Climate Replacement Help
Old Jul 19, 2006 | 08:49 AM
theesportscar's Avatar
theesportscar
Default Digital Climate Replacement Help
Does anyone have instruction or useful hints for removing the trim to get to the Digital Climate Control for replacement?
Old Jul 19, 2006 | 09:04 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just remove the trim panel, remove the controls, unplug and install.
It is that simple.
Dim display? Are you getting a new one or getting it repaired?
Good luck
Old Jul 19, 2006 | 09:54 AM
rws.1's Avatar
rws.1
I used the instructions from a Forum member Spdkilz
here's the link... although this one is to replace the LED's the access to do so is the same...
http://www.spdkilz.com/techtipledhvac.html
Old Jul 19, 2006 | 11:18 AM
theesportscar
Thanks! Great link. This will be very useful.
Old Jul 19, 2006 | 11:19 AM
theesportscar
Dim Display. Sending in to have unit repaired for $45
Old Jul 19, 2006 | 11:40 AM
rws.1's Avatar
rws.1
Are you using David Ruberg? CF member Mandigital... e-mail digitalguy_1@charter.net
Old Jul 19, 2006 | 10:30 PM
screw991le's Avatar
screw991le
Best way
Old Jul 20, 2006 | 12:37 AM
rikhek's Avatar
rikhek
Save the money and fix it yourself. If you or a friend can do the most basic soldering here's how most people fix the problem for free:
http://forums.corvetteforum.com/show...limate+control
And another:
http://forums.corvetteforum.com/show....php?t=1443580
Waste of time and money shipping it to someone for such an easy repair.
Rick
To Digital Climate Replacement Help
