AC seems cold only at idle?
Old Jul 20, 2006 | 09:37 AM
VetteMed's Avatar
VetteMed
Default AC seems cold only at idle?
THis is strange... At idle, the AC is ice cold. At higher rpm, such as when on the highway, it's lukewarm at best. I've always dealt with systems that got hot at idle, and cool off at higher rpm, due to low refrigerant, or a fan not running properly. Never encountered this scenario.
Any ideas?
Andrew
'01 Triple Black Z51 'vert (Possibly for sale/trade?)
Old Jul 20, 2006 | 09:47 AM
patton's Avatar
patton
St. Jude Donor '09
check basic stuff condensor clean belt slipping have some one hold rpms at 1500 ia ac cycling high and low side readings? if it needs suva dont put the whole can in . c5s are sensitive to over charge
Old Jul 20, 2006 | 09:52 AM
VetteMed's Avatar
VetteMed
What tends to go bad in the event of an overcharge, out of curiosity? I've been very careful about not adding any refrigerant if the low-side gauge is in the normal range, but then again, it's a cheapo parts-store gauge.
THanks,
Andrew
Old Jul 20, 2006 | 11:34 AM
danberry's Avatar
danberry
Had this happen to me in another GM car.........I found a vacuum leak in a small hose that controlled the air-heat-defrost box ,,,,max vacuum at idle ....everything where it should be.,,,,,as I moved and sped up lost vac,,,,and control box would shut off air......I found mine under the hood simply by feeling all of the small hoses that I thought were vac related..............good luck
Old Jul 21, 2006 | 03:23 PM
patton's Avatar
patton
St. Jude Donor '09
if you really overcharge you can lock up comp break belt . not too much over and you get reduced cooling. run it up to 1000 1500 rpms and look at low side. if 20 or so give it a small shot 1/4 can 1/2 can
Old Jul 21, 2006 | 05:15 PM
Jackal's Avatar
Jackal
I dont know about your problem but I do know that if you are at WOT the AC compressor turns off.
Old Jul 21, 2006 | 05:21 PM
djengr's Avatar
djengr
Try with open hood, turning A/C on full blast, have some one rev engine up slowly and see if compressor kicks off. If it is kicking off it it could be due to low suction pressue, or a loss of freon. You could go by a cheap suction gauge from auto parts store and see what pressure you are having on suction side. I bought one for about $20 at autozone.
Good luck and right now is not a time not to have A/C.
To AC seems cold only at idle?
