Help! Computer gone nuts?
The "change the oil soon" warning comes on, (I changed the oil in April, Mobil 1), the gas gauge flops to empty on a full tank, (done it before and fixed with Techron), the remote seems to be causing Vetty to honk several times, and sometimes unlocks the door, or locks the door, after I have put it in my pocket, and finally, the latest, the speedometer shows me going 70 while doing 40.The dealer mechanic
says, probably new computer. Is that what I am facing?
Please say it isnt so.
Thanks for the suggestions. Maybe there is a light at the end of the tunnel.
The battery was replaced this spring.
Being a "senior" lady vette owner, how do I check codes?
The mechanic was just trying to answer my question. I am not even sure he was a mechanic as he was at the desk for checking in.
I will try your suggestions after I learn how to do it, but I need to get going on it since the speedometer being off is not a good thing
#2 the guage flopping to empty on a full tank is common to a lot of vette mostly the early years and will require replacing of the sending unit in the tank.... both my vettes had this problem
#3 Is the remote set to auto lock? if so the car will lock and unlock every time you move near your car... its supposed to
#4 you arnt driving in "metric" mode are you? does the dash display KPH?
Hope this helps a little
To answer your questions, I did not reset the oil so that is solved. I also changed from metric to standard. Havent checked the locking thing yet, tho, Will do.
Still dont know about the speedometer. Maybe a loose wire somewhere.
Thanks.
Would the horn keep honking after I have locked the car and gone into the building, without my touching the fob? And when I get in the car, and close the door, I hear it clicking like its locking but the door isnt locked???? Weird!
I remedied the gas gauge by adding Techron when it was doing it a year ago and it hasnt done it since until yesterday, but now its okay again. Weird!! I had just filled it too.
Thanks for the tips and encouragment. I have solved the problem by simply reading the manual. Computer is fine.
I changed to standard, reset the oil thing, and reprogrammed the fob.
Talk about hitting the old panic button. I was dead sure I was going to have to install a new computer, per the "expert" at the dealership.
Thanks again, as I have learned a lesson and would rather talk to experts like you guys than a person who is going to try to get as much money out of me as he can. No Way.
