Alignment Specifications?
Old Sep 3, 2001 | 11:51 PM
TURBOTOC's Avatar
TURBOTOC
Default Alignment Specifications?
I will be replacing by Goodyear EMTs on my 2000 Coupe "Silver Sniper" with Michelin Pilot Sports. I will retain the standard wheels and tire sizes. The suspension is Z51 and most of my driving is aggressive and on the highway. I am looking for even tire wear.
What are the best alignment spec's for the new tires?
TURBO-TOC
Old Sep 4, 2001 | 12:12 AM
davidfarmer's Avatar
davidfarmer
Default Re: Alignment Specifications? (TURBOTOC)
I would go on the "performance" side of OEM:
front toe 0.04 individual
front camber -.5
front caster 6.9
rear toe -.01
rear camber -.48
This should give you good grip, but not cause too much wear. These are all withing the OEM tolerances, but a little into the more neg-camber settings.
Dave
