Halltech Mag does not clear hood!>
Old Sep 4, 2001 | 12:28 AM
RonWhite's Avatar
RonWhite
Default Halltech Mag does not clear hood!>
I have the liner off my hood and noticed that the MAG is rubbing the paint off! I checked to see if I could raise the hood a bit and could not. Anyone else have this problem with aftermarket air bridges? Also this is with the Stock hood as I no longer have the DRM!
Ron
[Modified by RonWhite, 11:29 PM 9/3/2001]
Old Sep 4, 2001 | 12:45 AM
intel55's Avatar
intel55
Default Re: Halltech Mag does not clear hood!> (RonWhite)
mine would rub a tad, but with the liner on it did not matter much to me. Maybe try enlarging the hole in the shroud so you can pull the front part down some and then the rest should follow. :cheers:
Old Sep 4, 2001 | 12:56 AM
RonWhite's Avatar
RonWhite
Default Re: Halltech Mag does not clear hood!> (intel55)
I'm running it with the Blackwing! It's in the stock location. I sent HAlltech an email and an I.M. and will give them a call tommorow to see if I can finally get them. I'll post Jim's response.
Old Sep 4, 2001 | 01:18 AM
99HRDTP's Avatar
99HRDTP
Ron-
It's the Blackwing. I had this trouble with my Donaldson LS6 (same filter) and the stock air bridge, and now, with the MAG, I still have the same problem.
Old Sep 4, 2001 | 01:23 AM
RonWhite's Avatar
RonWhite
Default Re: Halltech Mag does not clear hood!> (99HRDTP)
I didn't have this problem with the stock air bridge! It does not appear that it can go down any more than it does!
To Halltech Mag does not clear hood!>
