Need help
Old Jul 22, 2006 | 09:26 PM
98Roadster6speed's Avatar
98Roadster6speed
Default Need help
Well I found that the wires from the A/C pressure switch rubbed through & created a short fixed that but still have the problem stated below ???
I'm having touble with my pride and joy all the following happed at the same time ??? So I got a scanner & checked out my car I found the following codes
PO113 - IAT high voltage
P1111 - IAT intermitten high voltage
PO463 - fuel sensor level circuit high voltage
P1433 - fuel level sensor 2 high voltage
P1539 - A/C clutch feed back circuit high voltage
P1545 - A/C clutch relay control circuit
Also my oil pressure guage quit it is pegged out @ 131 psi ?
So my question is does any one know what this means , does this mean my PCM has gone bad ??? Why does every thing say high voltage ???
