how often should you change the trans fluid in a MN6?
Mobil 1 or AMS?
My Owner's Manual states: Manual transmission fluid doesn’t require change.
Originally Posted by Cobra4B
I run HPDE's in my car so I do it annually. I think GM says every 50k or something.
Thank you Brad (subdriver) for stepping up and clearing up the misinfo... guys if you aren't 100% sure what you're talking about in a tech forum please don't respond, spreading mininfo is not a good thing.
To properly change the fluid in the MN6, it should be flushed. This will take about 12 quarts... and the proper flush machine. If you live near a dealer you can TRUST, let them do it. It will be a much better job than a drain and re-fill at home.
I have an 02 MN6 coupe and since they day I brought her home with 43k miles I have been hearing a rattling noise from the rear end when shifting gears. I was told this was natural for a C5. Was I lied to and does this sound mean I need to flush and replace the differential fluid??
T56 trannys have low-rpm gear noise (mine's around 1000-1300 rpm) that sounds like a rattle. Assuming that's what you're hearing, everything's fine.
Other than that, give us more details.
HTH, and have a good one,
Mike
I'll pay more attention to what RPM I am running when I hear the rattle and let you know what I find; thanks for your input Either way I am thinking that I will go ahead and drain and refill my dif fluid this weekend while I have the car up on jacks replacing the rotors, calibers, pads and brake fluid.
