Engine torque specs for 2001 Z06
30 N·m
22 lb ft
Cylinder Head Bolt (Second Pass all M11 Bolts in Sequence)
90 degrees
Cylinder Head Bolt (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at The Front and Rear of Each Cylinder Head)
90 degrees
Cylinder Head Bolt (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
50 degrees
Cylinder Head Bolt (M8 Inner Bolts in Sequence)
30 N·m
22 lb ft
20 N·m
15 lb ft
Crankshaft Bearing Cap Bolts - Inner Bolts - Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap Side Bolts
25 N·m
18 lb ft
Crankshaft Bearing Cap Studs - Outer Studs - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap Studs - Outer Studs - Final Pass in Sequence
51 degrees
20 N·m
15 lb ft
Connecting Rod Bolts - Final Pass
75 degrees
