1998 no panel lights
Old Jul 25, 2006 | 09:10 PM
lb41j's Avatar
lb41j
5th Gear
Default 1998 no panel lights
Has anyone experienced the loss of dash panel lights? The headlights work, the interior dome light works but the cluster and radio lights do not work. The local Chevy dealership has no idea what the cause is but estimates $1500.00 to fix. Any help would be greatly appreciated; the car only has 64,000 miles.
LB
Old Jul 25, 2006 | 09:12 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Try the dimmer switch?
Old Jul 25, 2006 | 09:14 PM
PaceThis's Avatar
PaceThis
I'm assuming you're using the dimmer switch to move around and test them? Most common problem here is people have them all the way dimmed...
Next, I'd start with the dimmer switch itself as it's cheap, though probably takes 2 hours to change...possibly BCM if not that? Also, don't forget to check your fuses...
Old Jul 26, 2006 | 12:02 AM
VetteTech81's Avatar
VetteTech81
LB
LoL...
How can they give you an estimate if they do not know what the problem is?
-=Rick
Old Jul 26, 2006 | 07:47 PM
PaceThis's Avatar
PaceThis
The better question is how he'd know if it was a simple fix and they still charged him $1500...
Old Jul 27, 2006 | 10:19 PM
lb41j's Avatar
lb41j
5th Gear
To follow up on the suggestions, I looked at the dimmer switch and it will turn on the dome light but that is it. When I turn on the headlights the dash cluster lights do not come on nor do the taillights. If anyone can guide me in the right direction before I go to the dealership it would be much appreciated.
Old Jul 27, 2006 | 11:23 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Is your twilight feature on or off, and is this problem intermittent?
Old Jul 28, 2006 | 07:50 AM
VetteTech81
I believe I had a similar problem on a 99' I worked on, came in for tail lights in-op, and I believe the dash lights were not working correctly, The fix was replacing the multi function switch (turn signal switch).
They seem to be a common failure...
-=Rick
Old Jul 28, 2006 | 10:10 AM
lb41j's Avatar
lb41j
5th Gear
Hi Rick,
Thank you for the tip! The car runs great except for this light issue. I will give the switch a try.
Larry
Old Jul 28, 2006 | 11:03 AM
VetteTech81
Hi Rick,
Larry
No problem, if you want to know if the multifunction switch/TS switch is the answer get one, and before going through all the trouble of removing the switch, un plug the connector and plug the switch in, turn on the head lights and see if the tail lights are now functioning along with the ip lights.
Thanks,
-=Rick
Old Aug 5, 2006 | 05:44 PM
lb41j's Avatar
lb41j
5th Gear
Default Thanks VetteTech81
Rick,
I switched out the multifunction switch this afternoon and it fixed the problem! I appreciate your tip!
Take care,
Larry
Old Aug 5, 2006 | 05:46 PM
VetteTech81
Rick,
Take care,
Larry
Whoo Hoo!!! I'm happy that fixed it!
Glad I could help you out, let me know if you ever need anything such as accessories or performance parts ect... I'll take care of you..
-=Rick
To 1998 no panel lights
