Casing For 3:90 Gears
Old Jul 25, 2006 | 10:28 PM
jeanlucpicard's Avatar
jeanlucpicard
Default Casing For 3:90 Gears
I have an opportunity to pick up a 3:90 rear differential with hardened tail shaft built up out of a 3:15 case for my 2001 MN6 vert. I have the stock 3:42 rear differential now. I recall reading that the 2:73 cases are poor candidates for the 3:90 gear set due to added stresses cracking the case. Will a 3:15 case be strong enough for the 3:90 gear set?
Old Jul 25, 2006 | 11:59 PM
fdxpilot's Avatar
fdxpilot
Actually, the 2.73 case is a bad candidate because 3.90s won't fit without modifying the case, and only DTE does this on a regular basis. The case for 3.15s is the same as for all 3 and 4 series gears, so go for it. BTW - DTE will build a Stage 4 racing rear end out of a 2.73 case, so I don't think any of the cases has a strength issue (at least as compared to any other C5 case. You can still trash a DTE rear with enough HP or wheel-hop.)
Old Jul 26, 2006 | 06:52 AM
Mitch C's Avatar
Mitch C
To Casing For 3:90 Gears
