Physics majors, Part Deax
Old Jul 26, 2006 | 08:44 AM
6Speeder's Avatar
6Speeder
Default Physics majors, Part Deax
So you are driving your Vette, with a helium filled balloon on a string, tied to your shifter. Windows up, no air movement in the car, steady speed. If you step on the gas and accelerate the car, what will the balloon do?
Will it:
A. Move back
B. Stay where it is
C. Move forward
Old Jul 26, 2006 | 08:48 AM
Silver98's Avatar
Silver98
I say: it will move back. The only method of acceleration imparted to the baloon is via the string attached to the shifter. As the vehicle accelerates, the energy is imparted to the baloon via that string.
Old Jul 26, 2006 | 08:51 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
You guys have way too much time on your hands!!
Old Jul 26, 2006 | 10:04 AM
neverfastenough's Avatar
neverfastenough
If it's pitch black out and you turn your headlights on, will you see anything if your going the speed of light?
Old Jul 26, 2006 | 10:29 AM
MrEracer's Avatar
MrEracer
The balloon will move forward. This is because air is heavier than helium and the accelleration of the car moves the air mass back forcing the lighter balloon forward. This is like a centrifuge only in a straight line...
Shirl Dickey
Old Jul 26, 2006 | 10:56 AM
6Speeder's Avatar
6Speeder
DING! DING! DING!
WINNER
Try it some time. Doesn't seem right, but it does go forward.
Old Jul 26, 2006 | 11:04 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Simple as Newton's First Law of Motion. Every object in a state of uniform motion tends to stay in that motion unless an outside force is applied. In this case, it's a state of non-motion and the force is the string. The question is about the air that supports the balloon? You would think it cause the balloon to move backward because it, too is at rest?
Old Jul 26, 2006 | 11:33 AM
EHS's Avatar
EHS
Clearly not a French quiz.
Old Jul 26, 2006 | 12:25 PM
PR'Corvette's Avatar
PR'Corvette
6speeder have you done it already?? sounds weird I thought it would remain motionless until the string starts to pull it and tehn remain backwards.
Old Jul 26, 2006 | 01:43 PM
6Speeder's Avatar
6Speeder
Yes I have done it. Funny, Huh?
Old Jul 26, 2006 | 01:58 PM
itchynackers's Avatar
itchynackers
Actually, thats not exactly true.
The balloon will move forward RELATIVE to the pavement.
The balloon will move backward RELATIVE to the car.
Old Jul 26, 2006 | 04:32 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Sorry, not correct -- try it some time.
The balloon moves forward relative to the car (as well as the pavement).
This is not because the car acceleration somehow causes the air to move "back" to the rear of the car (to then push the balloon forward), but because the air's inertia prevents it from moving with the car until the car's rear window starts to push the air molecules forward. As the rear window advances, it essentially compresses the air from behind, creating a higher pressure in the air in the rear portion of the passenger compartment. It is this transient higher pressure air which pushes the balloon forward.
Old Jul 26, 2006 | 04:52 PM
Warp Factor's Avatar
Warp Factor
Shirl Dickey
Except that the balloon might initially move backwards very slightly, following the air movement toward the rear of the car.
Net movement would be forward.
Old Jul 26, 2006 | 05:08 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Ok, so you have an enclosed C5 with a bunch of bees in it. At first all the bees are resting on the floor of the C5. Next all the bees are flying in the C5. What happens to the weight of the C5 when the bees go from resting to flying?
Old Jul 26, 2006 | 07:14 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
In my case, the car instantly gets 190 lbs. lighter...
Old Jul 26, 2006 | 07:45 PM
Humanoid 2.0
Old Jul 26, 2006 | 07:49 PM
LoneStarFRC's Avatar
LoneStarFRC
I know that's right.
To Physics majors, Part Deax
Old Jul 27, 2006 | 01:54 AM
gpracer1's Avatar
gpracer1
The car weighs the same.
The air pushing down from the wings to keep them up, pushes on the car.? Are they Africanized?
Old Jul 27, 2006 | 06:40 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
An Irish priest, a Rabbi, and a lawyer walk into a bar.......Oh wait.... wrong thread..... :o
Old Jul 27, 2006 | 08:08 AM
BobbyG's Avatar
BobbyG
You get the living $hit stung out of you!
