external temperature sensor does not reflect correct temp
Old Jul 26, 2006 | 11:04 AM
mrsbcross's Avatar
mrsbcross
4th Gear
Default external temperature sensor does not reflect correct temp
I recently purchased a '98 vette. About a week after I purchased it, I noticed that the external temperature sensor doesn't accurately display the external temperature. For example, it might be 75 degrees in the garage, but the external temp displays 32 degrees. At first, after the car was out for a while (5-10 minutes), the external temperature would gradually climb to the correct temp. Lately, however, the external temp isn't changing. I live in New Mexico and it hasn't been 32 degrees in many months; however, that's what the external temp is reading. The problem is that because the temp reads 32 (or 39, or 46 degrees --it varies), the car desparately wants to turn on the heater. With it being 96 degrees here, the heater is the last thing I want.
I've taken the car in once, but they couldn't diagnose the problem. Any ideas? Anyone else have this problem?
Thanks!
Old Jul 26, 2006 | 11:07 AM
EHS's Avatar
EHS
The external temperature sensor has nothing to do with turning on the heater. You do that by setting the inside temperature desired.
It could be the sensor, it could be the HVAC system.
Easier to replace the sensor first.
Old Jul 26, 2006 | 11:10 AM
racetchr's Avatar
racetchr
You might try changing the OAT (outside air temp) sensor. It is fairly easily acessed. Lower front of car on pass side, close to radiator fairing.
Old Jul 26, 2006 | 11:16 AM
fej's Avatar
fej
The car could be using driver setting 1 or 2 which was set and stored the heater/ac setting as well. That could be a possible cause of your issue. As for the temp reading sorry no clue
Fej
Old Jul 26, 2006 | 12:02 PM
JC in XTC5's Avatar
JC in XTC5
A lot of misinformation here.
The external temp sensor affects the operation of the HVAC system. For example, if the temp reading is less than ~38*F, the AC will not be allowed to turn on. In fact, even if you set the HVAC to the coolest setting of 60*F, the system will not blow cold air (only fresh outside air) since the AC is disabled. Your sensor is likely bad or the connector has corroded affecting the impedance of the circuit.
To temporarily fix your problem, unplug the sensor and the temp will default to ~ 58*F, which will allow your AC to operate. The sensor is located under the nose of the car on the passenger side of the radiator cavity just above the air dam. You can reach it by raising the hood and reaching down between the frame rail and the rad cavity - just unplug the connector.
The sensor itself is only about $12. You may need to also check the connector for corrosion to may sure it's not part of the problem. You HVAC is probably fine.
Old Jul 26, 2006 | 01:49 PM
mrsbcross's Avatar
mrsbcross
4th Gear
John, you seem to have understood the problem perfectly. I'll replace the sensor and take a look at the connectors.
Thanks so much--I really appreciate your help and advice!
Thanks everyone else for your input
Old Jul 26, 2006 | 06:33 PM
EHS's Avatar
EHS
The external temp sensor affects the operation of the HVAC system. For example, if the temp reading is less than ~38*F, the AC will not be allowed to turn on....
John -- Like Betty said, you know your stuff.
Betty posted: "The problem is that because the temp reads 32 (or 39, or 46 degrees --it varies), the car desparately wants to turn on the heater. With it being 96 degrees here, the heater is the last thing I want."
Like I said in my post, "The external temperature sensor has nothing to do with turning on the heater."
That's correct, right, John? Where's the "misinformation"?
Heater is not the same as A/C, yes?
Just checking.
Old Jul 26, 2006 | 10:15 PM
debmwb's Avatar
debmwb
Just checking.
I would think that the mis-information is possibly in the statement that "the external termperature sensor has nothing to do with turning on the heater." That statement would imply that the temperature sensor has nothing to do with the climate control system. If the external temperature sensor is indicating that it is 32 degrees to the climate system, then the climate system will try to turn on the heater if the in car temperature was say set at 75.
Old Jul 27, 2006 | 12:18 AM
JC in XTC5's Avatar
JC in XTC5
My comment was geared to the suggestion that implied the sensor has not impact on the HVAC system, or this is a memory setting issue.
Although the problem description was the system was trying to trying to turn the heater on, I interpreted that as the system was blowing hot air rather than cool. If you consider that the air temp coming out of the HVAC is determined by what the OAT sensor reads, with a low OAT reading the HVAC will assume the outside temps are low and compensate (at least initially) by biasing the air mix doors towards the heated air side.
No offense to anyone. I just try to answer technical questions with some analytical thought.
Old Jul 27, 2006 | 01:38 AM
gpracer1's Avatar
gpracer1
If the temp sensor is unplugged, it reads 69.
I had one that was missing on my last car. The plug that was still there would get wet and read from 10 to 69 and the AC would not work at the lower temp reading. A brand new sensor from the dealer is $11. It takes about 2 minutes to install. Just get one and go from there.
Old Jul 27, 2006 | 12:53 PM
vanslam's Avatar
vanslam
Cruising
I had the same problem on my 2000 C5. I replaced the sensor and it still reads 39. When I get home I'll look at the connector and clean it. In the mean time I will unplugg it for the AC to work.
Old Jul 27, 2006 | 02:24 PM
EHS's Avatar
EHS
Not correct. The heater is controlled by the interior temperature sensor, which could care less what the outside temperature is. If the temperature inside the car is 100 degrees, even if the outside temp is indicating 32, and the setting is 75 degrees, trust me, the heater will not turn on.
Here is a picture of the sensor being removed. That's the one I'm talking about:
Old Jul 27, 2006 | 10:36 PM
LKGRenegade22's Avatar
LKGRenegade22
Does anyone have a picture of the external temperature sensor that is near the air dam?
Old Jul 27, 2006 | 11:00 PM
EHS's Avatar
EHS
Drawing work?
Old Jul 27, 2006 | 11:04 PM
JC in XTC5's Avatar
JC in XTC5
Yes, along with external sensor, the internal sensor adjusts the airflow temp as the system begins to run as well as the sun load sensor on the dash.
I think the point here is that he's in New Mexico, so even if the system adjusts the airflow temp to full cool, the AC can't kick in so all you're getting through the vents is fresh outside air which is about 100*F in that neck of the woods.
Old Jul 27, 2006 | 11:10 PM
EHS's Avatar
EHS
... I think the point here is that he's in New Mexico...
She?
Just a hunch.
Old Jul 27, 2006 | 11:28 PM
LKGRenegade22
Drawing work?
That's it! That's exactly the piece I have. Now I have to find the plug that goes into and take all the dang parts off to put that on! Thanks man!
To external temperature sensor does not reflect correct temp
Old Jul 27, 2006 | 11:30 PM
LKGRenegade22
EHS, does that sensor have to placed right there in the skid plate or can it be placed somewhere else? I don't really look forward to taking the parts off to get to that spot again.
Old Jul 27, 2006 | 11:41 PM
EHS's Avatar
EHS
I don't think it knows where it is, if you don't tell it.
But it probably likes shade and fresh outside air the best.
Old Jul 27, 2006 | 11:49 PM
LKGRenegade22
Well I will find out because I don't think it will go back to where it used to be unless it can somehow figure out it is in the wrong spot.
