Thunder Racing CLB not working
Old Jul 26, 2006 | 11:02 PM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Default Thunder Racing CLB not working
I just installed the CLB mentioned above. No matter what I do, I can't get rid of the SERVICE COLUMN LOCK message. I pulled fuse 25 (and 23 per the long sticky post on CLB's) and it wont go away.
I can hold the CLB relay in my hand... it energizes when I turn the key, and drops out in about a second. The DIC message comes on then. If I reset the DIC, the DIC is in the "trip" mode.
Also, I can start the car with the SERVICE COLUMN LOCK message on.
BTW... car is a 2004 Z06 6 speed with 2500 miles on it. No Dealer work done to it, and never had a problem with the column lock...
I give... any ideas?
I'm convinced that the unit either is bad, or doesn't work on a 2004. I can remove the device and the car functions normally. Reinstall it and the problem comes right back. I'll call them in the morning....
Old Jul 27, 2006 | 02:21 AM
Cscokd's Avatar
Cscokd
Yes....I'll tell you exactly what to do. Your CLB is working just fine. Your 2004 has the relay mod installed from the factory. To verify it, go look at your column lock harness connector. If the wires from the BCM are white, purple, green, black you have the mod. This relay will introduce relay switching glitches which will cause your CLB OR K Harness to operate unreliably. PM me with your email address and I'll send you instructions on how to remove this relay circuit.
John
Old Jul 27, 2006 | 02:50 AM
RFJohnston's Avatar
RFJohnston
Originally Posted by Cscokd
PM me with your email address and I'll send you instructions on how to remove this relay circuit.John
PM sent. Thanks!
Old Jul 27, 2006 | 04:50 AM
thorn92's Avatar
thorn92
If anyone can help, it's John...a great man!!!
Old Jul 27, 2006 | 09:24 AM
TEXHAWK0's Avatar
TEXHAWK0
John
I would also like to know what would cause the error message on an 04 Z06. Does it depend on when the car was produced?
I have a 2004 Z06 that I used a Thunder Racing CLB on for a year with no problems and no codes. Then I removed the lockplate and installed the GM Harness K kit(original kit with the good relays), and it has been working for 2 years with no problems or codes. What's the difference in mine and RF's Z?
I have not looked at it in awhile, but I am fairly sure my wiring is black, white, purple, green as you describe.
Old Jul 27, 2006 | 09:27 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
I'd like to know also, just out of curiosity. Mine is a '04 Z and I just installed a CLB with no problems.
Old Jul 27, 2006 | 12:01 PM
RFJohnston's Avatar
RFJohnston
Default Update
Called Thunder Racing... they said this is the 2nd one they have had this month that didn't work on a 2004 Z06. They said they needed to check on something and call me back, so I will wait to hear from them.
Cscokd sent me directions to solve the problem. (Thanks John!) I'm going to wait to change anything further until I hear back from Thunder Racing.
More later...
Old Jul 28, 2006 | 11:01 PM
RFJohnston's Avatar
RFJohnston
That was Wednesday the 26th... called Thinder Racing today... They say they are "researching the situation." I say What is there to research? This certainly isn't a new problem... Will try the tip I got from Cscokd tomorrow, and if this doesn't work, I'll put it back to stock. I hate user created problems where none existed... not to mention nonexistant support.
Old Jul 29, 2006 | 02:20 AM
Cscokd's Avatar
Cscokd
Guys, I just sent a detailed writeup to texhawk with a 3M file. I hope he got it as he hasn't answered yet. I believe the 04 Z06 cars have the GM relay mod added at the factory. I've debugged several of these cars where we found this relay. This relay will not always cause a problem. It all depends on the actual relays in the circuit and how sensitive they are. Anyone else wanting my Column Lock Tutorial, just email me and I'll send it to you, but beware it's a big file.
John
john_neese@msn.com
Old Jul 29, 2006 | 11:36 AM
TEXHAWK0's Avatar
TEXHAWK0
John
john_neese@msn.com
I got the e-mail, and the file is still downloading (just kidding). It does take awhile.
I am looking over the slides and trying to digest why not all 2004 cars have a problem. As pointed out, it may have to do with the sensitivity of the relays, ie a large slow relay actually works better in this application. I went to a Harness K kit on my car because I hoped that GM had some reason for keeping the actuator in the circuit. Originally it was thought it might be just to keep the proper resistance in the circuit to prevent premature failure of the relays in the BCM, but it may also just be an attempt to make the circuit operated more reliably.
Note: The Harness K is designed to keep the actuator in the circuit, but some forum members have used the Harness K and left the actuator disconnected, and the system still functioned without errors. However, I think the case I read was on a '97 model where they were getting errors with the aftermarket version, but did not get errors with the Harness K installed as described.
Old Jul 29, 2006 | 12:05 PM
RFJohnston's Avatar
RFJohnston
So are you saying that the CLB didn't work on your car too?
Old Jul 29, 2006 | 02:53 PM
RFJohnston's Avatar
RFJohnston
Yes....I'll tell you exactly what to do. Your CLB is working just fine. Your 2004 has the relay mod installed from the factory... PM me with your email address and I'll send you instructions on how to remove this relay circuit.
John
Thank you John! You were right. The relay mod was factory installed, and caused the problem. I removed the relay and put the jumper in and it worked like a charm. I owe ya a cold one at the next Santa Clara Corvettes meeting...
Old Jul 31, 2006 | 01:58 PM
TEXHAWK0's Avatar
TEXHAWK0
The CLB worked on my car while I had it in there. I switched to the GM harness because I thought GM had a reason to keep the actuator in the circuit. The discussion was that it would keep the correct resistance in the circuit and possibly prevent long term failure of the BCM, but I am still not sure if that has been substantiated.
Old Jul 31, 2006 | 03:00 PM
Tact's Avatar
Tact
It must not effect all '04 Z's as my CLB bought from Corvettes of Houston worked fine on my car with no problem. Glad you got yours fixed.
Old Aug 1, 2006 | 02:26 AM
Cscokd's Avatar
Cscokd
This extra relay we've all been talking about located near the BCM was installed on MN6 cars only (I think). It appears to be a feeble attempt by GM to prevent the column lock motor from receiving a LOCK command while driving. While the column lock motor was connected and working, it's response is so slow (seconds) that it would never see these timing glitches on the UNLOCK or LOCK signals. Then GM installed the K Harness and removed the lock plate. I'm coming to the conclusion that they left the column lock motor connected because it acted as a filter of sorts to dampen out any relay switching glitches which allowed the K Harness to operate more reliably. Unfortunately they chose a cheap relay and their efforts have been in vain. The problem is that the K Harness AND the CLB switch in milliseconds compared the column lock motor. So any switching glitches on the LOCK or UNLOCK signals may cause the CLB or K Harness to unintentionally change states. This is why many have observed that their CLB switches as expected but then immediately switches back again. When this happens, the BCM becomes confused, displays error messages and commands the PCM to shut off the fuel. I also know many of the later model MN6 cars came from the factory with the extra relay already installed. I'm not sure what year it was added to factory built cars. So my advice to this point has been to remove it and bypass it. In nearly every case removing this extra relay has solved any CLB operational problems. Why do some cars with the extra relay work with the CLB and some don't? My thinking is variations in relay sensitivity, switching speed, temperature, etc. Get rid of this relay. Use the KISS technique - "Keep It Simple Stupid". I hope this helps explain things a bit better. As always, I'm glad to help if you get stuck...just email or PM me.
Cheers,
John
Old Aug 9, 2011 | 09:55 AM
Z06seal's Avatar
Z06seal
Will this need to be done on a '03 ('02 build though) too? I'm going to order the clb, but maybe I should take that relay out?
Can I get the instructions on this too?
I also need to see if the previous owner installed a clb... I wonder why my wheel won't lock up, but I get the message... Fuel shuts off at 2mph too (going to edit that in a few hours via hp tuners)
To Thunder Racing CLB not working
