Lowering question.....
Old Jul 26, 2006 | 11:42 PM
ttboyvette's Avatar
ttboyvette
Default Lowering question.....
I lowered my car front and back longer bolts in the rear, and cut the bushings in the front and backed off the bolts as far as they go.
The question is.... My front passenger is 1/2" higher than the driver??????
Any ideas????
Tom
Old Jul 27, 2006 | 03:51 PM
FKING1's Avatar
FKING1
Measure from the frame (front same on both sides) to ground on a level surface. Should be nearly the same. From wheel arch to ground may vary 1/4" or so with even frame measurements. I would adjust frame specs side to side with the bolts.
Fred
