Need a quick response regarding wiper motors...
Old Jul 27, 2006 | 02:53 PM
Vetteman3's Avatar
Vetteman3
Default Need a quick response regarding wiper motors...
I just replaced the wiper motor on my 99. I am having a difficult time getting the wipers to seat after the last wipe after I turn off the switch. Can anyone advise me as to what the problem might be. I think it has to do with the connection to the motor but I am not sure...PLEASE HELP!!!!!
Old Jul 27, 2006 | 03:03 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Open the hood, pop off the plastic caps that cover the wiperarm nuts, losen the nut with a socket then adjust the wipers to there proper seated off position, tighten the nuts and replace the caps.
Old Jul 27, 2006 | 03:13 PM
Vetteman3's Avatar
Vetteman3
I did try this...When the wipers complete the last swipe of the windshield they are supposed to go almost to the seated position and just about stop and slowly return to the resting place on the cowl. Mine are not doing that...that final hesitation is not happening....ANY IDEAS?????
Old Jul 27, 2006 | 03:38 PM
patton's Avatar
patton
St. Jude Donor '09
when they go to park the motor reverses. in the module there is a cam. when yoy r+r ed it was it a complete assembly? did you remove center torx bolt for arm?
Old Jul 27, 2006 | 03:41 PM
Vetteman3's Avatar
Vetteman3
It was a complete assembly and Yes I did remove the torx bolt from the center of the motor. I had to to replace the motor...Any Ideas????
Old Jul 27, 2006 | 04:06 PM
patton's Avatar
patton
St. Jude Donor '09
u r+r ed the arm ? that is not a complete assm. what does the arm look like ; spring around it ,slot and pin
Old Jul 27, 2006 | 04:08 PM
Vetteman3's Avatar
Vetteman3
Yes - spring around it - slot and pin....
Old Jul 27, 2006 | 04:21 PM
patton's Avatar
patton
St. Jude Donor '09
it is easier with the cowl off arms on . key on run wipers on low 3or 4 sweeps reach in and turn off watch arm on motor it stop then reverse direction 1/2 turn . did it come with a module bolted underneath 3 or 4 small torx . is the arm linkage free no rust stains . if you r+red the mod. did you put the cam in the right pos. the arm is splined [fine] hard to get in proper pos. get it wrong the wipers will try to wipe the hood
Old Jul 27, 2006 | 04:25 PM
Vetteman3's Avatar
Vetteman3
There is no module underneath that I can see...The linkage is free from rust. I think the cam / spline probably moved. Do you have any advise as to how this can be adjusted????
Old Jul 27, 2006 | 04:39 PM
patton's Avatar
patton
St. Jude Donor '09
i'll get my 99 books down . 1 elect connector going to this? try to feel underneath square plastic cover got youre old motor? the books are buried in loft cant promise right away its cocktail hour here in trenton . i like to tease the bar maid. something about if she can get a ride in it she,ll wear some french underwear for me. oh i see it now vapor lock of the heart. i got nitrous but i need nitro pills
Old Jul 27, 2006 | 05:16 PM
Vetteman3's Avatar
Vetteman3
I do not have the old motor...Had to give the core back when I purchased the new one....Bye the way - mine is now BLOWN!!!!!!!Good luck with the BarMaid!!!!
Old Jul 27, 2006 | 10:45 PM
patton's Avatar
patton
St. Jude Donor '09
why did you replace the wiper motor? did the new one fix that problem? is whats happening now a brand new problem. when they stop is it always in the same pos. ? all other functions work except park? from limited info i would say 'park switch' in mod. if this is a brand new problem ,take it back. i never had good luck with rebuilt wiper motors. either they would not delay,park or spray
To Need a quick response regarding wiper motors...
