TORQUE CONVERTERS____A good Choice ?
Old Jul 29, 2006 | 03:23 PM
BGDDYKWL's Avatar
BGDDYKWL
I know when I changed gears on my other car it really woke it up, and provided a lot more punch when even just tapping the pedal. Will say a 3200 TC do this, or is it gonna only increase the performance in the higher RPM range?
Old Jul 29, 2006 | 04:25 PM
Vette_Fan's Avatar
Vette_Fan
I didnt understand that. Changing to a 3200 TC will increase performance in higher RPM range only, or lower RPMs too? I've heard from some ppl that a higher stall TC will make the car feel "loose". I still don't understand this term. My bad. Does that mean the car will slide all over the place, (kinda out of control feeling), or just "slugish" in lower RPMs.
Since I'm not so familiar with TCs, I'm thinking how about I just change the 2.73 gears to the 3.42. But then, a lot of ppl tell me I should chang the TC too.. Can anyone explain the term "loose" to me, and what affects a high stall Tc will have on Low RPMs & Hi RPMs..
Thanks guys...
Old Jul 29, 2006 | 04:47 PM
pawngod's Avatar
pawngod
i think loose means slip...the tc lets the tranny slip to raise rpm of engine for more torque then the tc kicks in w/higher rpm ...for a stronger pull
Old Jul 29, 2006 | 05:00 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
The term loose, refers to needing to step on the gas pedal more before the car will roll. Todays t/c's are much more effecient than even just a few years ago. With the 3200 stall you might notice that you need more throttle to get the car rolling, of course you might not. When I installed the 3200 I could not tell a difference between stock. When I installed my current 3600 I could tell the difference.
Old Jul 29, 2006 | 05:41 PM
Vette_Fan's Avatar
Vette_Fan
That helps. Now, can someone Plzzz tell me if I change -
#1. 2.73 gears changed to 3.42 what to expect. (Stock TC)
#2. Change to 3.42 + 3200 TC, then what to expect.
I guess, I'm trying to figure out the difference in the two set ups .
Old Jul 29, 2006 | 06:25 PM
Vette_Fan's Avatar
Vette_Fan
ttt ...
Old Jul 29, 2006 | 09:28 PM
jetning's Avatar
jetning
2.73 - 3.42= whooo
273-3.42 and 3600 tc = whoooooooooooooooooooooo
Old Jul 29, 2006 | 09:43 PM
16Again's Avatar
16Again
Originally Posted by jetning
2.73 - 3.42= whooo
That sums it up pretty well.
Old Jul 29, 2006 | 11:35 PM
debmwb's Avatar
debmwb
But...you will need more than that to hang with a 2004 SC/Cobra (especially if it's modified).
Just the 3.42's (no converter) is a great improvement!
Old Jul 29, 2006 | 11:58 PM
DarknessC5's Avatar
DarknessC5
Now I'm scared. I just bought a used TC from a member on LS1tech. Has anyone ever had a TCI converter rebuilt? What should I expect to pay for a rebuild?
Old Jul 30, 2006 | 03:29 AM
Boo383's Avatar
Boo383
One thing you need to be aware of is that with street tires and a stall converter. You will destroy the tires any time you try to launch hard!
Drag radials or slicks will be required to get the full benefits of the stall. That is what I have been told many times thru research. I plan on doing a 3.42 gear and a Yank SS3200 stall. I called Yank and told them I wanted the car to fell tight enough so my mom could drive it and that is what they suggested. It should be good for about 6 tenths or better improvement in the 1/4 mile.
Old Jul 30, 2006 | 04:34 AM
BGDDYKWL's Avatar
BGDDYKWL
My understanding, and please correct me if I'm wrong, is that going to a 3200 TC will definitely affect the car differently than going from say 2.73 to 3.73 gears. The gear change will make the car feel a lot faster at every point in time. Immediately off the line in the 1,500 rpm range, to passing on the freeway going 75mph. With the TC, the car will actually feel slower when moderately accelerating from a stop, assuming you're in the 1,000-2,500 rpm range, but will greatly improve performance when you really get on it. If you're primarily using the car for daily driving, and are typically below 3,000-4,000 rpm, the gears will make a whole lot more of a difference than the TC.
Old Jul 30, 2006 | 04:39 AM
  #33
SLPRC5's Avatar
SLPRC5
3.42's get that feeling first it will be a fun car...keep in mind there will always someone else badder..so if you looking to kick butt..supercharge it and call it a day...
Old Jul 30, 2006 | 04:41 AM
  #34
SLPRC5's Avatar
SLPRC5
well said my $.02 is 3:42's are best for the A4 as a daily driver. Gas mileage won't be effected as much either.
Old Jul 30, 2006 | 06:18 AM
  #35
Mitch C's Avatar
Mitch C
IMO that is not true. I have had 4 different stalls in my car. Stock with 3.15s, 2400 with 3.42s,3500 and now 4200 with 3.73s. My car never felt slower with a higher stall T/C. While it is true you have to give it a litte more throttle the car feels quicker IMO. You should also remember that gears alone will NOT remove the dead spots in acceleration you sometimes get when you go WOT from a roll. Only a higher stalling T/C will give you great acceleration from almost any speed.
Old Jul 30, 2006 | 12:13 PM
  #36
Vette_Fan's Avatar
Vette_Fan
This the the theory thats holding me back, or confusing me still. I don't wanna have SLOW / dead spots in Low RPMs. While I'm making a right hand turn on a light I don't wanna be in 2500-3500 RPM range. On the road, I wanna be able to drive the car like any normal car with auto, and still have power and torque. Thats why I'm switching to 3.42, so it will give me an all-the-time power/torque. But I wanna be able to launch hard too from a light, if I wanted to... for that I'd like a TC that fits into my driving style.
Plz keep the comments coming. They're very helpful... Thanks..
Old Jul 30, 2006 | 01:37 PM
  #37
dndrsn's Avatar
dndrsn
Does any one know what RPM the stock torque converters are rated?
To TORQUE CONVERTERS____A good Choice ?
Old Jul 30, 2006 | 01:48 PM
  #38
16Again's Avatar
16Again
Don't let the theory hold you back, it's flawed. You will not be at 3200 rpms before the car rolls, 3200 will be your power band, at 3200 you get it all. Now stock at 700 rpms your car rolls just fine, the new converter will now require 750 rpms to get the car rolling, you will not even notice the difference. New converters are much different than converters of just 2-3 years ago. You will notice very little difference from stock unless you move to a very big converter.
Old Jul 30, 2006 | 06:12 PM
  #39
Vette_Fan's Avatar
Vette_Fan
That's kinda what I'm talking about and looking for my car to do. But say, Im driving in a 30-40 miles/hr Zone, or residential area 25-30 mph, will I need to push the gas paddle FAR to get the same drivibility that I had with stock TC? And with the new 3.42 gears, how would that play a role in all this - at low speeds such as these?
Thanks!
Old Jul 30, 2006 | 06:15 PM
  #40
16Again's Avatar
16Again
That's kinda what I'm talking about and looking for my car to do. But say, Im driving in a 30-40 miles/hr Zone, or residential area 25-30 mph, will I need to push the gas paddle FAR to get the same drivibility that I had with stock?
Thanks!
Nope it will be EXACTLY like stock. The converter will come into play when starting out from zero (with the 3200 you should not notice much, maybe 50-100 rpms) The converter will shine in a HUGE way at full throttle and above 3000 rpms.
