Vert, 65+mph wind noise????
Old Jul 28, 2006 | 10:16 PM
wettvette's Avatar
wettvette
Default Vert, 65+mph wind noise????
at speeds above 65 i get wind noise around the windows, is this normal, is there a fix, is it a major. (roof on of course)
Old Jul 28, 2006 | 11:30 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
The windows are adjustable. First you need to isolate where the leak is. You can do this by sticking a rubber suction cup, like you use to hang a wreath on your front door, to the inside of the window then go take a drive at speed and pull on the suction cup with your left hand as you drive. My '02 vert has a minor air leak at 65 mph and above and I isolated it this way. When I pull on the suction cup while it is attached on top front part of driver's window the leak sound stops. This tells me I need to adjust the top of the window in a little. There are instructions on adjusting the tilt of the windows in the factory shop manual. I am sure you should be able to get the directions through Tech tips somewhere here on the forum. Good luck on solving this problem.
I know how to fix my problem easier than adjusting the window and that is just riding with the top down. You will smile more!
Old Jul 29, 2006 | 12:03 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
why is your roop up?
Old Jul 29, 2006 | 12:27 AM
wettvette's Avatar
wettvette
good point. Because its winter , not quite warm enough to have it down, although believe me i have tried. i have located that the noise is coming from the top at about the 2 0clock position if you sitting in the driver seat looking out, mine a 2002 , i wonder if its a 2002 thing
Old Jul 29, 2006 | 07:16 AM
jbvette96's Avatar
jbvette96
I also have an 02 vert and just noticed the noise at above 65mph with the top an windows down. I hear like a whistling noise, is that what you are hearing as well?
Old Jul 29, 2006 | 09:54 PM
SteveGel's Avatar
SteveGel
I have the same problem on my 01 Z06.
Old Jul 30, 2006 | 01:10 PM
shifter502's Avatar
shifter502
Have you checked your rear window to make sure its not coming undone from the top. Mine was which caused a sucking wind noise as opposed to a forced wind noise. I sealed it back with 3M window adhesive. Just be sure you let it cure completly before you try the top or it may come undone again.
Old Jul 30, 2006 | 02:33 PM
Cscokd's Avatar
Cscokd
Yep...had this problem for many years and tried all the usual stuff and none of it worked well. I even made GM replace my top, mechanic ride along and listen and adjust it countless times. GM couldn't fix it, so I installed my B&B Bullets and now the annoying wind noise is completely gone.
And BTW, they eventually leak too.
To Vert, 65+mph wind noise????
