Power for RAPTOR shift light
Old Jul 29, 2006 | 03:33 PM
AFBombdude's Avatar
AFBombdude
Default Power for RAPTOR shift light
Just got my new raptor light. I couldn't find anywhere where you guys had hooked up the switched 12v wire. I have found the tach wire under the dash but instead of probing all those wires I thought I would ask first. THANKS!!
Old Jul 29, 2006 | 03:47 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You can get an add-a-circuit and wire it to you fuse box or if your car is 2003 or older you should have the acessory pigtail located just above the BCM. There will be three wires taped together, yellow, orange, and black.
Old Jul 29, 2006 | 05:17 PM
AFBombdude's Avatar
AFBombdude
Thanks!
Anything closer to the tach wire by the steering wheel?
Old Jul 29, 2006 | 05:42 PM
Cajundude's Avatar
Cajundude
Originally Posted by AFBombdude
Thanks!
The big orange one that goes to the key is switched.
Old Jul 29, 2006 | 07:15 PM
AFBombdude's Avatar
AFBombdude
Thanks Cajundude!!
I will get my 12V from there.
To Power for RAPTOR shift light
