brake bias spring.......
Old Jul 29, 2006 | 09:04 PM
ML06's Avatar
ML06
3rd Gear
Default brake bias spring.......
in a 2003 z06 master cylinder, wich spring is replaced?
Old Jul 30, 2006 | 12:05 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
can't use it in 03 I think you have bias built in the system.
Old Jul 30, 2006 | 12:26 AM
Bill Dearborn's Avatar
Bill Dearborn
01 and newer C5s had dynamic rear brake proportioning.
The dynamic rear proportioning (DRP) is a control system that replaces the hydraulic proportioning function of the mechanical proportioning valve in the base brake system. The DRP control system is part of the operation software in the EBCM. The DRP uses active control with existing ABS in order to regulate the vehicle's rear brake pressure.
No need for a spring. Basically, it means if the rear tires have traction the system will add more rear brake bias. If you are running sticky tires on the track it could add a lot more rear pressure and cause the rear brakes to wear faster.
Bill
Old Jul 30, 2006 | 01:57 AM
ML06's Avatar
ML06
3rd Gear
As I Feared.......thanks For Your Input Gentlemen!
To brake bias spring.......
