HID shake
Old Jul 30, 2006 | 11:11 AM
skidmarc's Avatar
skidmarc
Default HID shake
Hey guys anyone install HIDs and have them shake on you over ever lil bump? My Infiniti with original equip doesn't and its quite annoying. If so, what have you done to resolve?
Thanks for any info/guidance!
Skid
Old Jul 30, 2006 | 01:57 PM
FourG63 97GST's Avatar
FourG63 97GST
hmm, well i guess you checked everything to see if it tight.
but this is probably normal. assuming you have projectors. its just the sharpness of the cutoff point that makes the "shake" more noticable.
Old Jul 30, 2006 | 05:20 PM
JTS97Z28's Avatar
JTS97Z28
yeah he's right. Also assuming you are using projectors there isnt much you can do about it. I have HID projectors as well and its just the nature of the pop-up headlight housings and the super sharp cutoff. There is no way to make them 100% stiff. I have tried almost everything.
JT
Old Jul 30, 2006 | 08:37 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
The extra cantilever weight of the projector hanging out the back is probably the problem. I have the same and so does another that has the HID projectors.
Old Jul 30, 2006 | 09:45 PM
skidmarc's Avatar
skidmarc
Hmmm. It is not the sharp cutoff since I am used to that with my Infiniti. The sharp edge isnt annoying but rather kinda the bright spot towards the middle jumping almost as if the bulb were loose. I guess everyone has the same issue. Just sux paying $1200 and they shake.
To HID shake
