2000 corvette vert problems?
Old Jul 31, 2006 | 03:35 PM
casinomgr's Avatar
casinomgr
Default 2000 corvette vert problems?
Hi
I am about to buy a 2000 vette with 53K miles loaded. Any Mechanical problems to look for on that year. Should I have it taken to a shop before buying it. I drove it, but not very long, it is sweet and drive great. I can probably get it for 24K (he wants 27,500) but has been for sale a while. He will take 25, I know that. Any one with a 2000 know of mec problems that can happen? a/c, engine, ANYTHING? Pete you out there, I just sold my 85. I am afraid of something mechanical going wrong with the 2000. Should I get an after market warrenty? Please guys, you have help me in the past....Any feedback so I can decide. Do not want to have any issues after paying 25K (or 24K) it. She is a BEAUTY but I am not mech smart!
Thx CF again
Old Jul 31, 2006 | 03:51 PM
Dennis 01's Avatar
Dennis 01
My wife and I have a 2000 6 speed convertible that we
purchased 2 1/2 years ago and love it .
We have 44,000 miles on it and have not had any problems.
The only thing mechanical that I did to the car was I installed the column lock bypass.
The most fun car we have ever owned.
Buy it and enjoy it.
Old Jul 31, 2006 | 03:59 PM
casinomgr's Avatar
casinomgr
Default 2000 convertable tops
Are all the 200 convetable tops manual? I thought they were a push of a button but the one I looked at was fold back manual. Any one?
Old Jul 31, 2006 | 04:20 PM
ayeroff's Avatar
ayeroff
All convertible C5 corvettes (1997-2004) have convertible tops that manually fold up and down. Chevy didn't start offering a power convertible top until the C6 model (2006 and on).
Old Jul 31, 2006 | 04:21 PM
spider94r's Avatar
spider94r
We have a 2000 Vert with 96k miles on it. It's been great. No problems aside from the ones all C5's are prone to. If it's been maintained well you'll have no problems.
Kevin
Old Jul 31, 2006 | 09:20 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Only had one problem with a popup head light. Cars has about 24K miles!
Old Jul 31, 2006 | 09:36 PM
StevenK's Avatar
StevenK
5th Gear
Default Love my 'vert
Had a rear end leak that was fixed under extended warranty, otherwise no problems.
Old Jul 31, 2006 | 09:49 PM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
I have a 2000 and have had no major issues with it. Okay, there was that rock through the oil pan, but that was not a common defect! If the car checks out I'd go for it, that seems really reasonable. Warranty is up to you, that's a whole 'nuther thread. Good luck.
Bruce
Old Jul 31, 2006 | 09:54 PM
GrayC5's Avatar
GrayC5
Good luck with the purchase!
Old Jul 31, 2006 | 10:27 PM
rws.1's Avatar
rws.1
check the digital display for the AC... is it bright and readable in daylight?
Does the fob lock and unlock both doors everytime?
is their a leak on the drivers side of the rear differential?
get the VIN and ask someone here to run a service history to see what work has been done on it...
run a Carfax
how much tread left on the tires?.... IF you want runflats a new set if needed will set you back about $1400
Old Jul 31, 2006 | 11:19 PM
EHS's Avatar
EHS
OK -- 2000 convertible; problems I've personally had:
1. Excess oil consumption (800 miles to the quart).
2. Fuel sensors (replaced three times).
3. Harmonic balancer (replaced once).
4. Directional signals (hazard switch replaced).
5. Bouncing headlight (headlight motor replaced).
6. F45 shocks (leaking fronts replaced at 33k).
7. Rear differential seal (replaced twice).
8. Oil pressure sensor (replaced).
9. Various AIR check valves (rusted and replaced).
10. Belts (replaced with harmonic balancer).
11. Seat bolster (the driver's side issue).
12. Squeeking/inop seatbelt retractor.
13. Column lock actuator and motor.
14. Two new key fobs.
15. BCM replaced.
Yeah, I think that's about it, other than normal maintenance.
Good luck.
Old Aug 2, 2006 | 01:40 PM
casinomgr's Avatar
casinomgr
Default bad luck
15. BCM replaced.
Good luck.
Wow sounds like you had some problems. That stinks. Everyone I have spoke to says what great cars and now ya got me thinking. Did you spend alot of money for all the problems? Was it worth it in th elong run?
Old Aug 2, 2006 | 03:28 PM
EHS's Avatar
EHS
Yes, it was worth it.
All items with the exception of the key fobs were either replaced under the original warranty, or a GMPP with a $200 deductible.
Check the TSB record for the car (www.alldata.com) and you will see quite a number of those listed. The others you can find here on the forum. None were "non-standard" items.
To 2000 corvette vert problems?
