How to check car for codes?
Old Jul 31, 2006 | 11:41 PM
redrocket87's Avatar
redrocket87
Default How to check car for codes?
Gang,
Part of the C5 learning curve is that I'll have to ask some seemingly basic questions.
Can I check if my car shows any error codes by any button sequence or do I need to buy some sort of scanner?
Thanks in advance
Old Jul 31, 2006 | 11:46 PM
rws.1's Avatar
rws.1
How to Enter Diagnostic Mode
The "diagnostic display" mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options"
4) While holding "options", press "fuel" four times within a 10-second period.
When first engaged the on-board diagnostics go into an "automatic" mode which shows all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, you will see "no more codes" on the ICP display.
The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem.
When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back.
To exit the diagnostic mode at any time, press "E/M". If you want to erase or "clear" codes, press " reset
DTC Descriptor
DTC B0016, B0017, or B0018 Right Front/Passenger Frontal Deployment Loop (Stage 1) Circuit
DTC B0022, B0024, or B0026 Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit
DTC B0051 Deployment Commanded
DTC B0053 Deployment Commanded with Loop Malfunctions Present
DTC B0090 Active Switch Voltage Out of Range
DTC B0091 Active Switch: Wrong State
DTC B0332, B0333, B0337, or B0338 Air Temperature Sensor Circuit
DTC B0348 Sunload Temperature Sensor Open
DTC B0361, B0363, B0365, or B0367 HVAC Actuator Feedback Circuit
DTC B0432 Rear Defogger Relay Circuit
DTC B0433 Rear Defogger Relay Circuit
DTC B0441 or B0446 HVAC Actuator Out of Range
DTC B0502 RH DRL Relay Circuit
DTC B0503 RH DRL Relay Circuit
DTC B0507 LH DRL Relay Circuit
DTC B0508 LH DRL Relay Circuit
DTC B0516 Speedometer Signal Circuit Malfunction
DTC B0521 Tachometer Signal Circuit Malfunction
DTC B0605 BCM Internal Memory Malfunction
DTC B0846 or B0851 Battery Out of Range
DTC B0856 5 Volt Reference Out of Range
DTC B1000 ECU Malfunction
DTC B1001 Option Configuration Error
DTC B1512-B1537 Driver Information Center (DIC) Switch Circuit
DTC B1542 Oil Temperature Circuit Short to Ground
DTC B1543 Oil Temperature Circuit Open
DTC B2172, B2177, B2182, B2187, B2192, or B2197 Power Seat Switch Circuit
DTC B2202-B2208 Window Switch Circuit
DTC B2222-B2224 Mirror Select Switch Circuit
DTC B2226-B2234 Mirror Switch Circuit
DTC B2236-B2239 Door Lock Switch Circuit
DTC B2242-B2244 Memory Switch Circuit
DTC B2252-B2253 Door Key Cylinder Circuit
DTC B2262-B2265 Mirror Position Sensor Signal Circuit
DTC B2272-B2273 Mirror Motor Control Circuit
DTC B2274-B2275 Window Motor Control Circuit
DTC B2276-B2277 Door Lock Control Circuit
DTC B2282-B2285 Battery 1 or Battery 2 Voltage Out of Range
DTC B2286-B2287 Mirror Position Sensor Circuit
DTC B2403 Front Fog Lamp Switch Circuit
DTC B2408 Rear Fog Lamp Switch Circuit
DTC B2482 Backup Lamp Relay Circuit
DTC B2483 Backup Lamp Relay Circuit
DTC B2527 Horn Relay Circuit
DTC B2528 Horn Relay Circuit
DTC B2567 Folding Top Release Switch Circuit
DTC B2573 Hatch Release Switch Circuit
DTC B2578 Right Front Turn Signal Monitor Circuit
DTC B2583 Left Front Turn Signal Monitor Circuit
DTC B2587 Column Lock/Unlock Drive A
DTC B2588 Column Lock/Unlock Drive A
DTC B2592 Column Lock/Unlock Drive B
DTC B2593 Column Lock/Unlock Drive B
DTC B2597 Traction Control System Switch Circuit
DTC B2600 Seat Motor to Battery Voltage
DTC B2605-B2607 Seat Position Sensor Circuit
DTC B2647 Ambient Light Sensor Circuit Low
DTC B2648 Ambient Light Sensor Circuit High
DTC B2721 PASS-Key Detection Circuit
DTC B2722 PASS-Key Detection Circuit
DTC B2723 PASS-Key Detection Circuit
DTC B2735 PASS-Key Programming Mode Active
DTC B2795 Suspension Control Select Switch Circuit Malfunction
DTC B2852 Telescoping Column In Switch Shorted to Ground
DTC B2857 Telescoping Column Out Switch Shorted to Ground
DTC B2860 Telescoping Column Position Sensor Failure
DTC B3109 Keyless Entry Transmitter Low Battery
DTC B3577 Suspension Control Select Switch Contact Malfunction
DTC C0550 ECU Malfunction
DTC C0563 Calibration ROM Checksum Error
DTC C0577, C0579, C0582, C0584, C0587, C0589, C0592, or C0594 Suspension Actuator Circuit
DTC C0578, C0583, C0588, or C0593 Suspension Actuator Circuit High
DTC C0615, C0620, C0625 or C0630 Suspension Position Sensor Circuit
DTC C0665 Chassis Pitch Signal Circuit
DTC C0690, C0691, or C0693 Damper Control Relay Circuit
DTC C0695 Position Sensor Overcurrent (8 volt supply)
DTC C0710 Steering Position Signal Malfunction
DTC C0750, C0755, C0760, or C0765 Tire Pressure Sensor Circuit
DTC C1214 Solenoid Valve Relay Contact or Coil Circuit Open
DTC C1217 Pump Motor Relay Contact Circuit Open
DTC C1218 Pump Motor Circuit Shorted to Voltage or Motor Ground Open
DTC C1221-C1235 Wheel Speed Sensor Circuit
DTC C1236 Low System Supply Voltage
DTC C1237 High System Supply Voltage
DTC C1241 MAGNA STEER Circuit Malfunction
DTC C1242 or C1243 Pump Motor Circuit
DTC C1247 Brake Pressure Differential Switch Activated
DTC C1248 DRP Disabled
DTC C1254 Abnormal Shutdown Detected
DTC C1255 or C1256 ECU Malfunction
DTC C1261-C1274 EBCM Internal Solenoid Circuit
DTC C1276, P1644, or P1689 Delivered Torque Circuit
DTC C1277 or P1571 Powertrain Indicated Traction Control Malfunction
DTC C1278 TCS Temporarily Inhibited By PCM
DTC C1281, C1283, or C1286 VSES Sensors Uncorrected
DTC C1282 Yaw Rate Sensor Bias Circuit Malfunction
DTC C1284 or C1285 Lateral Accelerometer Circuit
DTC C1287 or C1288 Steering Position Sensor Circuit
DTC C1291 Open Brake Lamp Switch Contacts During Deceleration
DTC C1292, C1293, or C1296 Master Cylinder Pressure Sensor Circuit
DTC C1294 Brake Lamp Switch Circuit Always Active
DTC C1295 Brake Lamp Switch Circuit Open
DTC P0101 Mass Air Flow (MAF) Sensor Performance
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0106 Manifold Absolute Pressure (MAP) Sensor Performance
DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0116 Engine Coolant Temperature (ECT) Sensor Performance
DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
DTC P0131 or P0151 HO2S Circuit Low Voltage
DTC P0132 or P0152 HO2S Circuit High Voltage
DTC P0133 or P0153 HO2S Slow Response
DTC P0134 or P0154 HO2S Circuit Insufficient Activity
DTC P0135, P0141, P0155, or P0161 HO2S Heater Performance
DTC P0137 or P0157 HO2S Circuit Low Voltage
DTC P0138 or P0158 HO2S Circuit High Voltage
DTC P0140 or P0160 HO2S Circuit Insufficient Activity
DTC P0171 or P0174 Fuel Trim System Lean
DTC P0172 or P0175 Fuel Trim System Rich
DTC P0200 Injector Control Circuit
DTC P0218 Transmission Fluid Overtemperature
DTC P0230 Fuel Pump Relay Control Circuit
DTC P0300 Engine Misfire Detected
DTC P0325 Knock Sensor Module Performance
DTC P0335 Crankshaft Position (CKP) Sensor Circuit
DTC P0336 Crankshaft Position (CKP) Sensor Performance
DTC P0341 Camshaft Position (CMP) Sensor Performance
DTC P0342 Camshaft Position (CMP) Sensor Circuit Low Voltage
DTC P0343 Camshaft Position (CMP) Sensor Circuit High Voltage
DTC P0351-P0358 Ignition Coil Control Circuit
DTC P0410 Secondary Air Injection (AIR) System
DTC P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit
DTC P0420 or P0430 Catalyst System Low Efficiency
DTC P0440 Evaporative Emission (EVAP) System
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0446 Evaporative Emission (EVAP) Vent System Performance
DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0461 Fuel Level Sensor Performance
DTC P0462 Fuel Level Sensor Circuit Low Voltage
DTC P0463 Fuel Level Sensor Circuit High Voltage
DTC P0480 Cooling Fan Relay 1 Control Circuit
DTC P0481 Cooling Fan Relay 2 and 3 Control Circuit
DTC P0500 Vehicle Speed Sensor (VSS) Circuit
DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
DTC P0506 or P0507 Incorrect Idle Speed
DTC P0522 Engine Oil Pressure (EOP) Sensor Circuit Low Voltage
DTC P0523 Engine Oil Pressure (EOP) Sensor Circuit High Voltage
DTC P0530 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0562 System Voltage Low
DTC P0563 System Voltage High
DTC P0567 Cruise Control Resume Switch Circuit
DTC P0568 Cruise Control Set Switch Circuit
DTC P0571 Cruise Control Brake Switch Circuit
DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610 ECU Malfunction
DTC P0608 Vehicle Speed Output Circuit
DTC P0645 Air Conditioning (A/C) Clutch Relay Control Circuit
DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit
DTC P0654 Engine Speed Output Circuit
DTC P0704 Clutch Switch Circuit
DTC P0706 Trans Range Switch Performance
DTC P0711 TFT Sensor Circuit Range/Performance
DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0719 Brake Switch Circuit Low Input
DTC P0724 Brake Switch Circuit High Input
DTC P0740 TCC Enable Solenoid Circuit Electrical
DTC P0742 TCC System Stuck On
DTC P0748 Pressure Control Solenoid Circuit Electrical
DTC P0751 1-2 Shift Solenoid Valve Performance
DTC P0752 1-2 Shift Solenoid (SS) Valve Performance - No Second Or Third Gear
DTC P0753 1-2 Shift Solenoid Circuit Electrical
DTC P0756 2-3 Shift Solenoid Valve Performance
DTC P0757 2-3 Shift Solenoid (SS) Valve Performance - No Third Or Fourth Gear
DTC P0758 2-3 Shift Solenoid Circuit Electrical
DTC P0785 3-2 Shift Solenoid Circuit Electrical
DTC P0801 Reverse Inhibit Solenoid Control Circuit
DTC P0803 Skip Shift Solenoid Control Circuit
DTC P0804 Skip Shift Lamp Control Circuit
DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1120 Throttle Position (TP) Sensor 1 Circuit
DTC P1125 Accelerator Pedal Position (APP) System
DTC P1133 or P1153 HO2S Insufficient Switching
DTC P1134 or P1154 HO2S Transition Time Ratio
DTC P1220 Throttle Position (TP) Sensor 2 Circuit
DTC P1221 Throttle Position (TP) Sensor 1- 2 Correlation
DTC P1258 Engine Coolant Overtemperature - Protection Mode Active
DTC P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit
DTC P1276 Accelerator Pedal Position (APP) Sensor 1 Performance
DTC P1280 Accelerator Pedal Position (APP) Sensor 2 Circuit
DTC P1281 Accelerator Pedal Position (APP) Sensor 2 Performance
DTC P1285 Accelerator Pedal Position (APP) Sensor 3 Circuit
DTC P1286 Accelerator Pedal Position (APP) Sensor 3 Performance
DTC P1336 Crankshaft Position (CKP) System Variation Not Learned
DTC P1380 Misfire Detected - Rough Road Data Not Available
DTC P1381 Misfire Detected - No Communication with Brake Control Module
DTC P1415 or P1416 Secondary Air Injection (AIR) System
DTC P1431 Fuel Level Sensor 2 Performance
DTC P1432 Fuel Level Sensor 2 Circuit Low Voltage
DTC P1433 Fuel Level Sensor 2 Circuit High Voltage
DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P1514 Throttle Body Performance
DTC P1515 Control Module Throttle Actuator Position Performance
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
DTC P1517 Throttle Actuator Control (TAC) Module Performance
DTC P1518 Throttle Actuator Control (TAC) Module Serial Data Circuit
DTC P1539 Air Conditioning (A/C) Clutch Feedback Circuit High Voltage
DTC P1546 Air Conditioning (A/C) Clutch Feedback Circuit Low Voltage
DTC P1574 Stoplamp Switch Circuit
DTC P1575 Extended Travel Brake Switch Circuit
DTC P1626 Theft Deterrent Fuel Enable Signal Lost
DTC P1630 Theft Deterrent Learn Mode Active
DTC P1631 Theft Deterrent Start Enable Signal Not Correct
DTC P1635 5 Volt Reference 1 Circuit
DTC P1637 Generator L-Terminal Circuit
DTC P1638 Generator F-Terminal Circuit
DTC P1639 5 Volt Reference 2 Circuit
DTC P1652 Powertrain Induced Chassis Pitch Output Circuit
DTC P1810 TFP Valve Position Switch Circuit
DTC P1860 TCC PWM Solenoid Circuit Electrical
DTC P1870 Transmission Component Slipping
DTC U1000 and U1255 Class 2 Communication Malfunction
DTC U1001-U1254 Lost Communication with XXX
DTC U1300, U1301, or U1305 Class 2 Data Link Shorted
Old Jul 31, 2006 | 11:50 PM
redrocket87
MAN! You type fast!
Thanks...
Old Aug 1, 2006 | 02:04 AM
GrayC5's Avatar
GrayC5
The following site is one of the best that I've found and has the codes specific to each model year. Once you've selected the model year, click on READ MORE toward the bottom of the next page that appears to review all the codes for that model year.
Corvette Computer Codes and DTC information
Old Aug 1, 2006 | 03:45 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
You can also scan codes with the engine running. I checked at a red light once for S&Gs and sure enough I could scan the codes sitting there idling. I was trying to isolate a random code I was getting and was checking for the code after driving over different road surfaces, grandma driving, "spirited driving" ect... Unfortunately I couldn't find my problem through a specific driving habit or sequence but it may be helpful to someone else... I should post this as a separate topic!
Tim
99 Coupe
Old Sep 7, 2006 | 07:26 AM
Logansar's Avatar
Logansar
Default Codes
I am new to the Corvette world (always dreaming.. just slow to get here!) and new to the Forum. I am amazed at the knowledge base that is here. This is a prime example. I wish I new about this prior to buying a Vette. I was lucky and found a great car, but would have loved to have known this to check the other cars I looked at for error codes.
BTW.. what does this mean in the post? - "all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA."
Are these the systems it is looking at?
thanks
Sgt Paul
Old Sep 7, 2006 | 10:14 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
thanks
Sgt Paul
Welcome Sgt Paul,
Also thank you for your hard work keeping justice in it's place amidst a crooked world!
Thanks,Matt
Old Sep 7, 2006 | 10:35 AM
BlackZ06's Avatar
BlackZ06
Yup ....
PCM - Powertrain Control Module - controls engine and automatic tranny
TCS - Traction Control (Electronic Brake Control Module) - controls the ABS, Traction Control and Active Handling
RTD - Real Time Damping - suspension control (if installed)
BCM - Body Control Module - controls vehicle lighting and other body functions (fuel door, trunk release, etc.)
IPC - Instrument Panel
radio - duhhhh
HVAC - Heating, Ventilation, A/C
LDCM/RDCM - Left/Right Door Control Modules (windows, locks, etc.)
SCM - Seat Control Module
RFA - Remote Function Actuation - radio receiver for fob commands and tire pressure sensors (if fitted)
Old Oct 21, 2006 | 08:47 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
good thread
To How to check car for codes?
