hot cam vs 02 LS6 Cam?
Old Sep 5, 2001 | 04:18 PM
4THTOY's Avatar
4THTOY
Default hot cam vs 02 LS6 Cam?
I am looking for a mild cam that will give me some additional power/TQ in the low/mid range, not just the high end, as I use my car as a daily driver. I was looking at these 2 cams as I think the PCM should be OK with either, any thoughts?
Ira
Old Sep 5, 2001 | 08:29 PM
99 Corvette's Avatar
99 Corvette
Default Re: hot cam vs 02 LS6 Cam? (3rdtoy)
Where can you buy the 02 Z06 cam? Is it any different from the 01?
Jerry
Old Sep 5, 2001 | 11:28 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: hot cam vs 02 LS6 Cam? (99 Corvette)
It will NOT idle with the hot cam. It's 112 LSA and fairly long duration are not friendly with the stock PCM. I have had 4 cams in my car and liked the hot cam the best. But no way would it hold an idle. ANDY
Old Sep 6, 2001 | 01:49 AM
Z51BOB's Avatar
Z51BOB
Cruise-In II Veteran
Default Re: hot cam vs 02 LS6 Cam? (Andy@AandACorvette)
Most of the hot cam users have drilled out the TB bypass hole to get a good idle. That seems to work.
I think the LS6 cam is a good compromise. With 116 degree lobe centers it idles well and produces some serious power.
Both will work with the stock ECM. The LS6 has more low end torque.
[Modified by Z51BOB, 11:54 PM 9/5/2001]
To hot cam vs 02 LS6 Cam?
