I recently posted an article explaining that I had electric dumps installed and I now have the pictures for you guys. The total install cost was high, but they actually did a clean job.
The dumps were mounted just before the stock mufflers. They are mounted to a Y-Pipe and than wired into the car.
Here is the drivers side dump. As you can see they are open as always.
Here is the passanger side dump.
They wired it into the trunk and ran the switch into the center console as you can see here.
sorry to tell you this, but you now are danger of breaking your rear leaf spring due to excess heat. At least that is the impression that I have gotten from reading similar stories on this forum.
