Does anyone here know C5 wheel specifics?
Old Aug 1, 2006 | 02:49 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Does anyone here know C5 wheel specifics?
We have a 4.75 inch bolt circle right?
What is the offset?
I'm trying to figure out other options in 16" besides CCW drag pack for the track. Thanks!
Old Aug 1, 2006 | 02:58 PM
MYCoupe's Avatar
MYCoupe
What is the offset?
That is the correct bolt circle. As far as offsets it depends on the wheels:
17x8.5" 58mm
17x9.5" 54mm (Z06)
18x9.5" 65mm
18x10.5" 58mm (Z06)
Old Aug 1, 2006 | 03:00 PM
Cajundude's Avatar
Cajundude
Cool, thanks!
Old Aug 1, 2006 | 03:28 PM
Roadking's Avatar
Roadking
And the options are????
Old Aug 1, 2006 | 03:32 PM
Cajundude's Avatar
Cajundude
Working on it... I'm reading a deposition right now. I actually had to stop and work for a while. Go figure. I'll report back when I find out something.
Old Aug 1, 2006 | 04:16 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The "correct" offset is entirely dependant on the wheel's width.
The offset number of a stock 18x9.5 means absolutely nothing if you want a 18x12 (for example).
Post up the actual size, if the car is tubbed or not, and I or someone else can tell you the ideal offset.
Old Aug 1, 2006 | 04:22 PM
Cajundude's Avatar
Cajundude
Thanks Tom! No tub, wheel needs to be 16" and as wide as I can get it. There seems to be several options with 16 x 12. Is that possible with no tub?
Old Aug 1, 2006 | 04:37 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Yeah, but it's gonna hang out of the fender a little. If that's ok, a 62-64mm offset should work.
Old Aug 1, 2006 | 04:44 PM
Cajundude's Avatar
Cajundude
That's cool since they are for the track. I'll see what I can dig up with those measurements.
To Does anyone here know C5 wheel specifics?
