Caliper Paint Question...
Old Sep 5, 2001 | 09:12 PM
Aceman's Avatar
Aceman
Default Caliper Paint Question...
OK,
This weekend I'll be installing the Z06 scoops and figured
since it's the first time I've had the wheels off, I'd paint
the calipers while I'm at it.
Couple of quick questions:
1. Do most of you use spray or brush on?
I'm leaning towards brush on since there is less taping
involved. If you've used brush-on, and had good experience,
what type/manufacturer.
2. I have 14K on the car, the calipers need to be cleaned.
Anything special to use besides a degreaser / soap?
3. Do I need jack pucks or can I use the jack that just came
with the car? I'm assuming it has the correct fitting for the
jack points, no?
4. Do I need to worry about torquing the lugs when putting
the wheel back on? If so, what's the torque and what will
a wrench set me back???
That's all for now. Thank you all for your anticipated help!
Aceman
Old Sep 5, 2001 | 09:29 PM
lillysride's Avatar
lillysride
Default Re: Caliper Paint Question... (Aceman)
#1 Are you you want do this yourself? #2 Use brush on. #3 Clean the calipers to remove greese dirt etc. #4 Use the jack that came with the car? See step # 1 :crazy:
Old Sep 5, 2001 | 09:39 PM
BatMobile's Avatar
BatMobile
Tropical Moderator
Cruise-In 1-5 Veteran
St. Jude Donor '03-'04-'10-'11
Default Re: Caliper Paint Question... (lillysride)
Step one...go look for your jack that came with the car...
let us know when you find it.
Neill
Old Sep 5, 2001 | 09:40 PM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
Your car came with a jack??? Where is it?? I don't think I got that option! :D
I painted my calipers a few weeks ago. Used a floor jack and put the car on stands. Removed the wheels, and used degreaser from Wal Mart to clean the calipers. I sprayed them, let them soak for a while, then dried them thoroughly. Then using painter's tape (blue masking tape) and plastic sheeting (also from Wal Mart) I masked off the everything that WASN'T a caliper. I used Rustoleum Sunburst Red (ALSO from Wal Mart) and painted the calipers one at a time.
After the paint dries (probably overnite) use some fine grit sandpaper to go over the raised "CORVETTE" letters on the front calipers for a nice finished look. Check this guy out for pics and tips...
http://www.2phast.com/calipers.htm
Good luck!
Dave
Old Sep 5, 2001 | 10:03 PM
Aceman's Avatar
Aceman
OOPS....One of those :jester moments.
Sorry, someone hit me with the idiot stick :smash:
OK - now that the jack question is clear, did you guys
worry about the torque on the lugs????
Aceman
Old Sep 5, 2001 | 10:15 PM
BatMobile's Avatar
BatMobile
Tropical Moderator
Aceman
YES!!
Worry about the torque on the lug nuts.
They should be set at 100 foot-pounds, incrementally from 30 ft-pd, to 60 to 90, then finished at 100.
People are finding that uneven torquing of the lugnuts can be responsible for warping your brake rotors.
Neill
Old Sep 5, 2001 | 10:49 PM
Drop_Top_Dave
Kid Rock Fan
Default Re: Caliper Paint Question... (BatMobile)
...YES!!
Worry about the torque on the lug nuts....
Uhhhhhh........uh-oh!! :eek: :eek:
Guess I know what I've got to do! :bb
Old Sep 5, 2001 | 11:06 PM
lillysride's Avatar
lillysride
OK, I'am sorry for the remarks, painting the cals is one thing, cutt'in big holes in the side of your ride is another! I think Jake at Corvette Concepts has done this as well as others. Measure twice cut once! Go for it Aceman! :seeya Now somone hit me with more taxes, Are you going to remove the Fog lamp area, or cut in rear brake ducts? :troll
[Modified by lillysride, 9:15 PM 9/5/2001]
Old Sep 6, 2001 | 10:39 AM
wwashing's Avatar
wwashing
Neill
I know the manual says 100, but I only torque my lugs to 90 ft/lbs, Does anyone else use this number. I've been doing this for 3 years and my wheels haven't come off yet?
Old Sep 6, 2001 | 10:53 AM
RedLandRocket's Avatar
RedLandRocket
Default Re: Caliper Paint Question... (wwashing)
I torque to 100-110 lbs.
Factory initially torques to 125 lbs
I like that paragraph in the owners manual. This car is not equipped with a spare tire, jack or any tools. i guess it changed on the Z06.
Old Sep 6, 2001 | 01:32 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Aceman,
The FoliaTec (and others) caliper paint kit come with a spray-on cleaner/degreaser.
If you use the brush-on, make sure you mix the paint in small batches! Once you mix, you need to use that paint within 10-15 minutes.
Also, use a sharp scraper or dremel tool to remolve the paint from the "Corvette" letters after the paint cures, but BEFORE it hardens completely. I did this after 2 hours.
I did the brush-on and am very happy with the results after 6 months - still look like brand new.
And don't forget to use a STAR pattern when tightening those lug nuts!
No-frills torque wrench from Sears: $30
[Modified by SDVette, 9:48 AM 9/6/2001]
Old Sep 6, 2001 | 03:39 PM
chuckoc's Avatar
chuckoc
I used spray paint (Made for Caliber painting High Temp) I used BRAKE CLEAN spay cleaner, I masked the poopie out the car and used bed sheets for the body as over spay will find your paint, The masking sounds and looks harder then it is just get out your exacta knife and a pair of scissors and don't be afraid to use little itty bitty pieces of tape to get what you want covered, there is no rule that says you must mask the area with one pieces of tape, I used hundreds of little pieces to get the coverage I wanted I used a screw driver to push the tape where I wanted it also. They look nice. when you are done, allow four or 5 hours if you are doing it yourself from pulling it in to setting down and cleaning up. Then drive tomorrow.
Old Sep 6, 2001 | 03:44 PM
Untouchable00's Avatar
Untouchable00
hahahaha look for the jack.
Old Feb 26, 2012 | 10:25 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
She's got the jack...(AC/DC reference....)
Old Feb 26, 2012 | 01:54 PM
jrose7004's Avatar
jrose7004
When you find that jack that came with the car, you let us know.
Old Feb 26, 2012 | 04:02 PM
Kmcoldcars's Avatar
Kmcoldcars
I painted my calipers with electron blue from paint mixed at the auto paint store and put in spray cans. I removed the calipers from the rotors but did not take the brake lines off. Be careful with the calipers. I cleaned them well, scuffed the surface with scotch brite pads, cleaned then with a paint degreaser and sprayed one side and after it dried overnight sprayed the other side. They still look fine after one year. For normal street driving you do not need a high temperature paint. For taking it on the track regularly you probably would.
<p>
<p>
<p>
Old Feb 26, 2012 | 04:38 PM
C5FORFUN2's Avatar
C5FORFUN2
Wow 11 year old post!!!!
Old Feb 26, 2012 | 06:04 PM
johnodrake's Avatar
johnodrake
Moderator
Indeed!
To Caliper Paint Question...
