Need help with one more turn signal problem.
Old Aug 3, 2006 | 12:05 AM
gojo's Avatar
gojo
Default Need help with one more turn signal problem.
The front drivers side turn signal doesn't flash as a turn signal or when the hazard flasher is on.
The brake lights are all working.
The hazard flasher works the tail lights and the right signal light, pulsing normally.
The left turn signal flashes only the right rear pulsing rapidly.
I swapped bulbs, no change. The left front is still out.
I swapped relays 38 and 40, no change.
Would the flasher do this? And, if so, is there any way other than removing the dash, to replace the flasher?
The trans was worked on. Are there any wires that could have been nicked?
Thanks!
Old Aug 3, 2006 | 10:24 AM
patton's Avatar
patton
St. Jude Donor '09
right after trans work? man made problems are the worst. how about day time running lights?
Old Aug 3, 2006 | 11:33 AM
gojo's Avatar
gojo
Other than the left turn signal all lights work.
Old Aug 3, 2006 | 01:18 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
I have the same problem with the passengers side front turn signal. Sometimes it works normally, then only the rear works with fast flash.
I've also repalced bulbs, checked the ground connections, didn't help.
I would also be interested in any input on this. It's really ticking me off.
Old Aug 3, 2006 | 04:26 PM
gojo's Avatar
gojo
I'm guessing it's the flasher. I hope not because I think the dash has to come off to replace it. I'll post when I fix it.
Old Aug 3, 2006 | 04:44 PM
1965imp's Avatar
1965imp
I had a simalar problem with my '98. The wires for the driver side turn signal run inside the front plastic bumper. I had some corroded wires inside the loom towards the left side. There are some delicate wire connectors that chevy uses and if you can get a good look at the loom on the drivers side you will see a lump...that is where the connectors are.
Old Aug 3, 2006 | 05:01 PM
gojo's Avatar
gojo
Good idea. I'll do it before the dash comes off.
Old Aug 5, 2006 | 01:23 PM
Jettech's Avatar
Jettech
The flasher can be changed by removing the radio. I just had to replace mine. http://forums.corvetteforum.com/showthread.php?t=860333
Old Aug 6, 2006 | 02:25 AM
EHS's Avatar
EHS
Replace the Hazard Switch.
Old Aug 7, 2006 | 04:33 PM
gojo's Avatar
gojo
No luck so far. I changed the flasher, switched all bulbs from right to left and checked any connections I could get to. The left front signal still doesn't work. I guess it's time to take it to the dealer. I left the bezel off so that should help some. The dealer sponsors our club and took the flasher back. They generally treat club members well.
Old Aug 7, 2006 | 09:02 PM
gojo's Avatar
gojo
Fixed, but it is odd. I switched bulbs from side to side twice with no luck. I figured it would be worth it to try a new bulb and it worked?
Trying to be positive at least I learned how to pull the switch without removing the dash.
I didn't see any tips for A4's.
When ready to pull the bezel, take your key off the key ring. You will need the room. Turn on the key put the car in 1st gear and the bezel will slide over the shifter (and the key).
For Vert's with the waterfall.
Remove the nuts in the back of the console and slide the tray over the bolts and back under the waterfall. It should go about an inch. This will give you enough room to muscle the front bezel off and on.
My hats off to anyone that can do this in 40 minutes.
I can probably do it in 75 minutes now that I've done it and if all goes smoothly.
I can't get the array of tools ready in less than 15 minutes.
Old Aug 8, 2006 | 11:24 AM
HRDTOPC54FUN
Thanks for the info. I'm going to try replacing both front bulbs and who knows, maybe I'll get lucky.
To Need help with one more turn signal problem.
