Engine difference in years 97-98 vs 99-04
Old Aug 3, 2006 | 07:52 AM
willig72's Avatar
willig72
Default Engine difference in years 97-98 vs 99-04
I have a 98 C5 and these are the 3 reasons Kenne Bell says their system won't work on the eariler C5 vets.
1. Front belt drive configuration
2. Heads
3. Fuel system
Who out there can tell me the difference in the 97-98 vs 99-04
And what does it take to make these changes?
Old Aug 3, 2006 | 08:28 AM
byte_me's Avatar
byte_me
2. Heads
3. Fuel system
I guess they didn't provide you with reasons why huh?
There are a few things- The cams were different, with the 2000 being the more aggressive one out of the newer bunch for the LS1....the fuel system on your 98 has two lines where as they changed this to one line on the later LS1's (you can see them both on the drivers side fuel rail cover) I believe you also have larger fuel injectors (but I can't see this being a bad thing)...some other internal block things as well with regards to oil passages and some say that the later LS1 has stronger internals...the heads also went to centerbolt vs. perimiter bolts that you have on your 98...in 01 all the LS1's used the newer LS6 design Intake manifold and they also changed exhaust manifolds from your two piece welded units to a cast design. I know on my 2000 I have the ABS module in the engine bay where I think yours is in the rear...but I doubt that has anything to do with it...my 2000 belt setup looks the same as my 97 did...also, there may be some ECM changes between the early ones as well...I had a 97 (same setup as your 98) and I know there were a lot of things I could not do that the newer ones could with regards to the ECM setting.
Hope this helps!
Old Aug 3, 2006 | 10:31 AM
xlr8shn's Avatar
xlr8shn
I put a 98 fuel system in my 99 because I wanted the fuel pressure regulator at the rail...
You can place the 99 system on your 98 and have the regulator in the fuel filter if you wish
Old Aug 3, 2006 | 05:27 PM
willig72's Avatar
willig72
Thanks for the information I don't yet see a big toe stuber with the differences. Anyone else out there know anything else?
Thanks again.
Old Aug 3, 2006 | 05:39 PM
SynistrC5's Avatar
SynistrC5
the drive configuration did not change
Old Aug 3, 2006 | 06:10 PM
byte_me's Avatar
byte_me
Thanks again.
I agree- either do I to be honest... can you get them to elaborate on each one as to exactly whay it won't work? I am sure someone has a blown early C5 out there...
What about the belt config-
Why not these heads-
Why not my fuel system-
Maybe you can ask ECS (a forum vendor) what they think...they have been known to do some pretty amazing things with these cars...
Old Aug 4, 2006 | 11:19 AM
Gordy M's Avatar
Gordy M
Also the PCM's were different, for SC you need to reprogram the PCM, that might also be the issue.
Old Aug 4, 2006 | 12:20 PM
4THTOY's Avatar
4THTOY
the 97/98's vs latter blocks have different oiling passenges in the main block than the later blocks, 97/98's also have different fuel systems and tend to run richer than the 99+'s, in 2001/2 the bottom of the blocks were changed to allow better breathing
I have a 98 and when I was starting the engine build up, I talked with a number of tuners most suggested starting with a later block.
Old Aug 4, 2006 | 05:35 PM
sugarwolf's Avatar
sugarwolf
My 98 forged Ls1 has had no problems when i built it up. I just changed the oil pump which i know all the earlier ls1's had problems with. Holdin 700+ hp boosted.. But thats not stock internals. I know the main thing was the rod bolts and oil pump on earlier LS1's Strength wise the newer blocks got thicker cylinder sleeves and different oil passages and a few other casting differences like for better oil control with windage.. I havnt had no problems with the 98 block, just remember if you build one up too grind off all casting flask so u dont get no cracks. And the LS1 earlier blocks can only go .005 over too on honing... Other than that not too much differance on blocks.. Also if you go with forged pistons you have to use LS1 edit to turn down the knock sensor sensativity..
To Engine difference in years 97-98 vs 99-04
