Check Engine Light On
Old Aug 3, 2006 | 08:28 AM
33bball's Avatar
33bball
7th Gear
Default Check Engine Light On
When I got my emission test done in March, my Check Engine Light came on and I was told to give it a couple days to see if it would go off. It did. but it still comes and goes. However, this last week it seems to stay on and the car will hesitate at 30-35 mph and 45-50 mph at times. Nothing is consistent but I did smell gas last night.
Help
Old Aug 3, 2006 | 08:37 AM
rws.1's Avatar
rws.1
I know it sounds dumb... but is your gas cap on correctly and tight?
The number one cause of check engine lights is caused by loose/missing gas caps....
Old Aug 3, 2006 | 09:04 AM
33bball's Avatar
33bball
7th Gear
Default check engine light on
doesn't sound dumb,,,,but yes, gas cap on correct & tight.
any other thoughts?
Old Aug 3, 2006 | 09:42 AM
Silver98's Avatar
Silver98
What are the DTC codes?
Old Aug 3, 2006 | 10:02 AM
33bball's Avatar
33bball
7th Gear
CODES ARE AS FOLLOWS:
PCM - P0200 & P0300
IPC - U1160H
LDCM - B2282H, B2284H, U1064H
RDCM - B2283H, B2285H, U1064H
SCM - B2860H
Old Aug 3, 2006 | 10:58 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
P0200 Injector Control Circuit
P0300 Engine Misfire Detected
guess that would make sense if you feel hesitation
U1160 Loss of Communications with LDCM
B2282 Battery #1 Circuit
B2284 Battery #2 Circuit
U1064 Loss of Communications with BCM
B2860 Telescoping Column Position Sensor Failure
Old Aug 3, 2006 | 11:05 AM
Wicked Weasel
go to this website it will help
P0200
http://www.gearchatter.com/viewtopic10473.php
P0300
http://www.gearchatter.com/viewtopic10471.php
33bball's Avatar
33bball
7th Gear
all of the codes that showed up had an "H" behind it. I thought if there was a current problem it would show up with "C"? However the 2 codes
P0200H Injector Control Circuit & P0300H Engine Misfire Detected would sound like a cause.
Is it just a simple tune up? Car is 2002. I've owned it for last 2 years and have not done a complete tune up yet?
Old Aug 3, 2006 | 11:11 AM
33bball's Avatar
33bball
7th Gear
ok, thanks!
Old Aug 3, 2006 | 02:23 PM
c5chris's Avatar
c5chris
Check your plug wires. When these guys test the car, they more than likely pulled on your wires, loosening one or 2 of them.
Mine had one that was almost pulled off the plug. It's good I checked it before I drove off.
To Check Engine Light On
