Need help with code 28 TCS C1227
Old Sep 5, 2001 | 09:57 PM
lazyace's Avatar
lazyace
Default Need help with code 28 TCS C1227
Been getting service active handling/service ABS/service traction control.
Only current code is 28 TCS C1227. Anyone know of this problem?
Thanks.
Old Sep 5, 2001 | 10:09 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Need help with code 28 TCS C1227 (lazyace)
Left rear excessive wheel speed variation.Possible sensor pigtail jumper harness or the sensor/hub itself.Check the connector to the L/R sensor.Check the sensor jumper harness for being frayed or damaged from road gremlins :smash: Faulty jumper harnesses (internal,not to the naked eye) are common...
Old Sep 5, 2001 | 10:14 PM
lazyace's Avatar
lazyace
Default Re: Need help with code 28 TCS C1227 (C-5 TECH)
Thanks C-5 TECH. I'm due at the dealership Tues for the Column lock fix. It's good to be able to tell them my other problem. This helps alot!
To Need help with code 28 TCS C1227
