LS1 Double Roller timing chain: Will it fit?
The only alternatives I have seen are the ones where the cut a factory cover in two and weld on flanges. There is a few places doing that. The QTP cover does not bolt together, they just glue up their seam. They have a small over lapping lip that they glue up. It looks fine to me, I don't think there will be a problem with leaks. I have not run this cover much so I don't know for sure but I don't think there will be any problem.
If you buy one, expect quite a bit of touch up work to make it fit well. What I would recommend is as soon as you remove your old cover, remove the gasket, put the new cover up against the block and shake it around a bit and see what hit. If you bead blast the cover first it makes it very easy to see where it hits. Start grinding with a die grinder where it touches. I had to grind a huge notch out of the bottom to clear the oil pickup. Don't worry, the cover is VERY thick down there, you can cut a lot. Keep trying and grinding until it fits. Once you replace the gasket you will have at least .050 clearance between the cover and any internal parts. If your installing a double roller chain then put your spacers under the oil pump, leave your pickup tube unhooked at first, and repeat the above steps until the cover fits without hitting. Then hookup the oil tube and repeat the process again until nothing hits.
If I had to do over I would buy another of these covers, they are nice covers, just takes a little work to get them to fit really well. I may try to make my own two piece cover now that I have a TIG, just to see if I can do it. I may be able to make a cheaper cover but I don't think I can make a better cover. The QTP cover is not cheap, but when you look at the size of the block of aluminum it takes to cut that cover from, it is a huge block, and how much machine time it would take to cut all that aluminum away. I think the price if a fair price.
