Just cruisin and threw a code... P0157
Old Aug 4, 2006 | 02:19 AM
5W0P3's Avatar
5W0P3
Default Just cruisin and threw a code... P0157
P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
I'm guessing something happened to it, I haven't had time to actually look at the o2 sensor yet, but i just put an X pipe and headers on, anyone have any thoughts on what it could be? wiring? the actual sensor? thanks!
Old Aug 4, 2006 | 07:43 AM
Mr. Jones's Avatar
Mr. Jones
If I got this right thats the rear passenger side 02 sensor.
most people have the rear 02's deleted after a header install.
All of that suface area cools the exhaust quicker and causes a
slow reponse from the 02 sensor.
I would clear the code and run it a little and see if you get the same code again.
Are you running cats?
Old Aug 4, 2006 | 11:44 AM
5W0P3's Avatar
5W0P3
I haven't got it tuned, i was going to do that this week or next. I am running cats, but i can see what you mean about the area. I was just hoping i didn't burn up a wire under there or something.
Old Aug 4, 2006 | 12:49 PM
Mr. Jones's Avatar
Mr. Jones
The tuner should help you out by turning the rear o2's off. You do want to make sure the wires do not come in contact with any exhaust parts. I installed some heat shielding on my disconnected rear o2 connectors.
I like to verify that all wires are tied up away from the pipes a week or so after any work in that area is done.
Old Aug 4, 2006 | 01:15 PM
5W0P3's Avatar
5W0P3
yea, so i just crawled out from under the car, looks like some of that black wrapping on the rear o2 wires had melted on the header. In the dark it looked like the wire had melted too, but i got a flashlight and it hadn't been touched. i got a zip tie and tied it back away from everything, cleared the code in the DIC hopefully it doesn't come back.
Old Aug 4, 2006 | 03:45 PM
Mr. Jones's Avatar
Mr. Jones
usually it will take two starts with a 20 min. run for each to verify if its clear.
hope all is good
Old Aug 4, 2006 | 05:07 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Had the same problem awhile ago and haven't had anymore codes after clearing that one.
Old Aug 4, 2006 | 05:56 PM
5W0P3's Avatar
5W0P3
so far so good. no codes yet.
Old Aug 6, 2006 | 01:43 AM
5W0P3's Avatar
5W0P3
Well, i guess i spoke to soon. It came back, but this time, the check engine light came on, so i get home. Turn it off. check the DIC and there are no current codes. So how do i clear it!? Obviously it's 1am, and i'm not about to go look under a car thats 200* in the Texas heat thats 100* (yes, its 100* at 1am!)
Old Aug 6, 2006 | 02:02 AM
EHS's Avatar
EHS
I had this code (both sides actually) with a very mild vacumn leak in the intake between the MAF sensor and the air bridge.
It would set, and sometimes with the C/E/L as well. Usually happened after a full throttle acceleration from a higher gear to redline, or in a long coast in gear down a hill.
Cured the vacumn leak, and no codes since (or CEL).
Don't know if that's your problem, but if you've been working on the intake, you may want to check that.
Old Aug 6, 2006 | 09:37 AM
sxeC7's Avatar
sxeC7
Go to "Tech Tips" in "Other" and scroll down to "Erase DTC Codes". That should clear up the check light. Your going to have to get O2 simulators or get the O2 sensors turned off to eliminate the problem.
Old Aug 6, 2006 | 11:24 AM
5W0P3's Avatar
5W0P3
I have a feeling that sxe60 and EHS are right. I'm going to do both.
To Just cruisin and threw a code... P0157
