Gear Ratio
Old Aug 4, 2006 | 11:44 AM
candapifer's Avatar
candapifer
From: Punta Gorda FL A Man's got to know his limitations!
Default Gear Ratio
Does anyone out there know what the stock gear ratio is for a 2002 coupe. Also, is this stamped anywhere on the car for reference or is there some other type of mark that would indicate this? Thanks.
Old Aug 4, 2006 | 12:08 PM
tiojames's Avatar
tiojames
Default diff
Stock for the 6 speed is 3:42, and for the auto is 2:73 with option of a 3:15 performance gear. The code is on the inside of the glove box.
Old Aug 4, 2006 | 12:22 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Or you could jack up your car and check out the tag on the right hand side that tells you what your gear ratio is.
To Gear Ratio
