16" Rims On C5 ???
Old Aug 5, 2006 | 02:53 PM
123sugey's Avatar
123sugey
Dig
Default 16" Rims On C5 ???
What Does It Take To Put A 16" F- Body Rim With A 26x11.50 X16drag Radial On A C5 ?
I Need More Traction On The Street And I Think This Is The Only Option ( More Sidewall ).
Old Aug 5, 2006 | 03:32 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I run 98 IROC wheels on the track and just minimal grinding needs to occur. I'll like to know the answer to this cuz that might open up more options for wheels before I order the CCW drag pack.
Old Aug 5, 2006 | 07:32 PM
Darkness's Avatar
Darkness
All you need to do is hammer slightly on the top cap of the control arm joint cover. No need to grind. C4 16" wheels fit as well but might need some adjusting.
I had the Fbody wheels on the tires that I have for sale now and they fit nice, not as purdy as CCW but for less than 50 bux a wheel you cant complain.
Old Aug 6, 2006 | 04:30 AM
Face's Avatar
Face
Depending on your alignment, you may or may not have to grind.
To 16" Rims On C5 ???
