all sensors lite
Old Aug 8, 2006 | 11:37 PM
cbucgo's Avatar
cbucgo
Default all sensors lite
I have a 99 6spd. car is in good shape and only has 65k miles. i have been doing some mods to car and everything seems to be ok. just recently i lowered car. i do not know if this has anything to do with it, but within a week of having car lowered, all dash lights are going nuts. the abs and trac control warning lights are on. the message display says low oil, low coolant, check abs, check trac cont. i know the car has no problems. i have check oil and coolant myself, plus brakes and trac work fine. I am afraid to take to GM. Afraid they will tell me i need 18 different sensors and will charge me megabucks for diagnostics. Any help??? Has anyone ever had brakes, abs, oil, and coolant lights all start acting up? Where can i start for self diagnostics?
Old Aug 9, 2006 | 01:03 AM
Gene Wolf's Avatar
Gene Wolf
I once read on this forum about similar unrelated gremlins popping up all of a sudden and it turned out to be related to a loose ground or rusty ground. As I recall, there are something like 5 or so grounds located throughout the body of the corvette, which might have gotten disturbed during your lowering. A definite maybe, anyway.....
Old Aug 9, 2006 | 07:12 AM
cenzo's Avatar
cenzo
First place to check is ground G104 located near the battery within the shroud. Disassemble, clean and reassemble. Then move on and do the others. This assumes a good battery, naturalamente!
To all sensors lite
