Dyno #'s on recent H/C LS1 upgrade
Old Aug 9, 2006 | 12:47 AM
SultansDiamond's Avatar
SultansDiamond
Default Dyno #'s on recent H/C LS1 upgrade
Just finished mod'ing the LS1 with LS6 heads & 220/220/114 cam. Six speed with shortie headers & honker. Pretty mild stuff. Here are the numbers:
Well, that didn't show up very well!
372.9 ftlbs 99mph 4801 rpm
378.4 hp 118mph 5744 rpm
Wish the numbers were bigger, but this result is very streetable and decent hp gains over the stock LS1
Old Aug 9, 2006 | 08:43 AM
6Speeder's Avatar
6Speeder
Not bad
Just gives you areas to improve, that's all. Throw on a set of long tubes, high flow cats, and an underdrive pulley. You'll pick up another 20 in HP and torque.
Old Aug 9, 2006 | 09:16 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Very nice indeed! Much more bolt on's out there to make her jump up even more look forward to seeing more numbers!
Thanks,Matt
Old Aug 9, 2006 | 09:43 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Very nice and now go out and drive her like you stole it
Old Aug 9, 2006 | 09:44 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
nice results
Old Aug 9, 2006 | 09:53 AM
Billdog350's Avatar
Billdog350
Also, those dynapacks are a bit more conservative than a dynojet I believe. I think you'd be putting down a bit more if you rolled the car on a dynojet. Regardless, those are great #'s. 445 crank hp...NICE.
Old Aug 9, 2006 | 10:21 AM
Cgillies86's Avatar
Cgillies86
Mustang Dynos read the lowest. Dynojets can read up to 10% higher than a mustang dyno. Dynapacks read higher than dynojets. I am not sure the percentage but they read the highest usually. Dynapacks give the highest numbers because you have to take the wheels off of a car to connect to one. I believe they connect to the wheel studs(i think), where as dynojets and mustang dynos read the power with the wheels on the car. So taking off the extra weight of the wheels inflates dynapack numbers.
Old Aug 9, 2006 | 12:50 PM
Billdog350's Avatar
Billdog350
I thought since the dynapacks were fluid dynos rather than a roller dyno, the numbers were more "accurate" and thus were usually lower than roller based dynos.
To Dyno #'s on recent H/C LS1 upgrade
