Need some help removing the Front bumper
Old Aug 9, 2006 | 12:49 AM
JerryX's Avatar
JerryX
Default Need some help removing the Front bumper
I'm thinking about repainting the front bumper. Has anyone removed their front bumper before? Thanks!
Old Aug 9, 2006 | 02:01 PM
94legaleagle's Avatar
94legaleagle
2 - 10mm bolts hold front fascia to each fender; access them through headlight opening
3 - 7mm screws in EACH wheelwell (in front of tire) attach front fascia to the inner wheelhouse
2 -10mm bolts at each edge of top of front fascia - kind of exactly where the hood gap is w/ the fascia when the hood is closed; also 4 push pin things there that need to be removed
5 - 7mm screws in middle of UNDERSIDE of fascia; these attach the fascia to the radiator shroud
misc 7mm bolts attach the fascia to the spoiler
remove all these bolts/screws and the fascia should pull off - should be able to do it in an hour or less
Old Aug 9, 2006 | 02:11 PM
dougbfresh's Avatar
dougbfresh
You can also get to the fender to fascia bolt from underneath with a long extension. Don't forget to unplug the electrics.
Old Aug 9, 2006 | 08:42 PM
Billdog350's Avatar
Billdog350
I think we're all assuming you mean bumper cover (fascia).....I hope you don't mean removing your actual bumper, which is welded to the frame and covered by foam.
94legaleagle has it right. Its not a horrible job but its made easier if you have those little combination metric gear wrenches and a good set of metric sockets. I left my tires on and used the gear wrenches on the 7mm bolts.
To Need some help removing the Front bumper
