Car Has Major Power Loss
Old Aug 9, 2006 | 01:28 PM
ss2z06's Avatar
ss2z06
Default Car Has Major Power Loss
I was getting on the freeway on sunday and shifted from 5th to 6th when the car experienced a major power loss. If feels like I am dragging a semi. I got no check engine light. I get it home( all gages fine). there is no noise from the motor. I checked the valve train. (no broken valve spring, rocker or bent push rod) I checked the plugs and they looked good. I checked compression and that is also good. I don't know what to do next. I have new plugs, wires, and fuel filter coming. I could use some advise on what to do.
Thanks!
-matt
Old Aug 9, 2006 | 01:54 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
is it only your shift from 5th to 6th or does it happen all the time now?
Old Aug 9, 2006 | 02:36 PM
ss2z06's Avatar
ss2z06
It is all of the time, now. It first started when i shifted from 5th to 6th(around 2,000 rpm).
Old Aug 9, 2006 | 02:59 PM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Catalytic Converter ? Does the engine sound sorta like its wheezing ? Had that happen in a 85 Firebird Trans Am. CC was clogged... Replaced and BAM, back up ad running full tilt...
Old Aug 9, 2006 | 03:44 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Happened to my 87 Firebird TA...lol!
Old Aug 9, 2006 | 04:56 PM
ss2z06's Avatar
ss2z06
This car has no CATS. It also has no MAF(converted to speed density)
Old Aug 9, 2006 | 05:50 PM
SilentFright
Maybe some corruption occurred with the speed density flash.
Old Aug 10, 2006 | 11:17 AM
ss2z06's Avatar
ss2z06
NEW UPDATE: I found the fuse for injection circuit 1 blown. Is there any common problems with this?
To Car Has Major Power Loss
