Fuel guage problem...HELP 8/9/06
Old Aug 9, 2006 | 10:54 PM
daveyb222's Avatar
daveyb222
4th Gear
Default Fuel guage problem...HELP 8/9/06
Just had the FSU replaced in my 97/C5/coupe/auto/51Kmiles...
Tried the techron first...finally got the FSU replaced at a dealer yesterday. Filled up the tank tonight and 21 miles later...chimes/check guages light/low fuel (DIC)/analog fuel guage at "0"...I can't believe it is happening again
Any one got any brain storms, aside from driving through the service department at some un-godly speed?
Old Aug 21, 2006 | 09:39 PM
sajonf's Avatar
sajonf
I just started having the same problem on mine.. 97 w/ 34K miles
Old Aug 21, 2006 | 11:06 PM
djh218's Avatar
djh218
Default Is this a common problem?
I don't think I conditioned my battery very well over the long winter ( I HAVE to get on a schedule for the two harleys, the pick-up, the jeep and the vette) so I think that low voltage caused problems with my FSU. It is intermittent; every now and then when I am driving, I get a message on the DIC to "checkgauges" and the analog fuel gauge goes to zero, as well as the HUD. It is very intermittent at this point, and I have found that by shutting the car off for a while (resets the computer???) or sometimes just getting gas and filling the tank, seems to solve the problem until the next time that this happems. I am starting to just use mileage and MPG figures to estimate when I will need gas again and to hell with the gauge...kind of like what I do on my H-D '94 wide glide which also has a feul gauge which sucks. Probably the best thing about this forum is that "misery loves company." I take some solace in the fact that I am not the only one who has these problems.
By the way, my 1990 C4 didn't go the dealer, it went to a priest to get exorcised...I was convinced it was possessed...LOL
Old Sep 4, 2006 | 11:18 AM
daveyb222's Avatar
daveyb222
4th Gear
Default Thanks for the help and advise
Well...after 2 trips to the dealer...and new Fuel Sensors units in both tanks...all is well now. The Techron helped a little but it kept coming back...thank god I had an extended warranty...$800 each trip/tank...believe or not the dealer filled my tank on the second trip
Old Oct 16, 2006 | 07:38 AM
bigbic2's Avatar
bigbic2
4th Gear
Default TSB Erratic fuel gage readings
there are two TSb for this condition. If you have only had the one pump assy replaced you may have to have the other side replaced as will.
To Fuel guage problem...HELP 8/9/06
