Cut Out Questions
Old Aug 10, 2006 | 11:16 PM
EVLZ06's Avatar
EVLZ06
Default Cut Out Questions
Where is the best place to run cut outs? What concerns should I have running cut outs besides the obvious water issue? Let me know some insight guys. Post up your under carriage pics if you have them.
Old Aug 11, 2006 | 12:41 AM
mfrejek's Avatar
mfrejek
I not familiar with the "obvious water issue", what exactly is it?
Old Aug 11, 2006 | 12:52 AM
EVLZ06's Avatar
EVLZ06
running "open" cut outs some times is a no no in the rain.
Old Aug 11, 2006 | 06:57 AM
mfrejek's Avatar
mfrejek
Ok, I'll bite.....why. Feel free to be as technical as you want in your explanation.
Old Aug 11, 2006 | 10:19 AM
Lowcash's Avatar
Lowcash
Here are some useful links regarding cutouts.
Link 1
Link 2
Old Aug 11, 2006 | 11:23 AM
SpeedyZ's Avatar
SpeedyZ
I agree, because when the cutout are open they sound so good your foot tends to stay on the floor, and with 400+ HP can be a no no in the rain!
Other than that I seen no reason it makes any difference when the cutouts are open or closed.
As for the best place, they will pretty much only fit in two places under a C5. The back between the mufflers and the area around the transmission. I think in the back is the best. But I went with them under the trans because I couldn't make them fit in the back with my factory Ti cat back.
Old Aug 11, 2006 | 05:37 PM
EVLZ06's Avatar
EVLZ06
Nice set up. Where did you get the turn downs? Are those QTP cut outs? Thanks for the pics
Old Aug 11, 2006 | 06:18 PM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
I believe those are these:
http://www.mccordcg.com/mpp/mpp.htm
Old Aug 11, 2006 | 06:29 PM
SpeedyZ's Avatar
SpeedyZ
Thanks , I put a lot of time in those. Those turn downs are stainless steel 2.5" pipe mandrel bent 90 degree bends I picked up on eBay. They were positioned down and back then sawed off flush with the bottom of the car. The short straight sections were cut from a 1' straight stainless steel pipe I got from the same seller on eBay. Could not find anyone who sold stainless steel flanges so I milled those out myself. I think QTP sells stainless flanges now. Did all the welding on the inside of the pipe for a clean look. Every thing you see there is bead blasted bare stainless steel, no paint, no coatings. The cutouts are McCord power plates. They are installed in a 3" LG X-pipe.
To Cut Out Questions
