Converting Fuel System ???
Old Aug 11, 2006 | 07:22 PM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Converting Fuel System ???
I own a 2004 coupe...How do i go about converting this to the 97-98 return style?
Old Aug 11, 2006 | 09:13 PM
BlueDream's Avatar
BlueDream
I'd recommend that you ask this question in the FI/Nitrous site. Lots of folks in that section have either done the conversion or has researched it. There are even some aftermarket upgrades that seem pretty straightforward as well.
Good luck, I may be doing the same thing in the near future.
Old Aug 11, 2006 | 09:42 PM
SmoothFRC's Avatar
SmoothFRC
I believe you need to basically swap out the tanks with a pre ffs fuel system, put in the hard return line, filter swap, and rail...
Old Aug 12, 2006 | 02:27 AM
2004SpiralGrey
can u use an adjustable fuel pressure regulator on a stock 2004 coupe fuel system???
Old Aug 12, 2006 | 10:52 AM
Darkness's Avatar
Darkness
Nope.
Old Aug 12, 2006 | 11:21 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
What is so great about a '97-'98 fuel system that would make a person go through all that work to convert it?????
Old Aug 12, 2006 | 11:26 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The later year fuel system wont support HIGH hp applications. The older 97-98 "Return Style"( It helps maintain higher fuel pressure) is the best system avail for this situation. That is of course until you go with an entirely new aftermarket setup like ECS or APS fuel systems.
Old Aug 14, 2006 | 12:53 PM
BiggieBoy's Avatar
BiggieBoy
Very interesting. Thanks for the info.....Have a good day...
To Converting Fuel System ???
