Instrument Cluster help
Old Aug 11, 2006 | 08:29 PM
cool60's Avatar
cool60
Default Instrument Cluster help
Has anyone had to replace the instrument cluster in a "98 c-5 or had trouble with one?
Old Aug 11, 2006 | 10:14 PM
lb41j's Avatar
lb41j
5th Gear
Default Yes
I have a 98 and the cluster lights and tailights did not illuminate. VetteTech 81 was able to diagnose the problem as a faulty multi-function switch (turn signal); it fixed my problem.
LB
Old Aug 11, 2006 | 11:17 PM
SpeedyZ's Avatar
SpeedyZ
I shot 128VAC into my IPC! It didn't work after that. I took it apart and found the diodes that got welded together and repaired it. I now know a lot more about the IPC than I ever wanted to know!
They are easy to remove, about 15 minutes if you don't have to go looking for tools.
Old Sep 10, 2006 | 08:43 PM
VetteTech81's Avatar
VetteTech81
What kind of problem are you having with it?
-=Rick
To Instrument Cluster help
