shifter help
Old Aug 12, 2006 | 01:30 PM
Taxin's Avatar
Taxin
St. Jude Donor '06
Default shifter help
does anybody know what the L shaped pin is for on the the front of the stock shifter Thanks for the help
Old Aug 12, 2006 | 04:50 PM
Roadking's Avatar
Roadking
You need to proof your post.
Old Aug 12, 2006 | 07:35 PM
cruisemon's Avatar
cruisemon
Default pin
The pin is used to align the neutral gate on the shifter.
Charlie
Old Aug 13, 2006 | 03:24 AM
Taxin's Avatar
Taxin
St. Jude Donor '06
Thanks for the info
Old Aug 13, 2006 | 08:02 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Lock the pin in the down position when installing/removing the shifter. Pull it up when you are done...
Peace
Willfulone
__________________
..................Click for
Old Aug 13, 2006 | 11:55 AM
Taxin's Avatar
Taxin
St. Jude Donor '06
I am installing a Kirban shifter and there is no spot for it are you saying to leave it in the shaft on the linkage or just leave it out Thanks for your help Willfulone
To shifter help
