New RunFlats, New Problem?
Old Sep 7, 2001 | 11:16 AM
Flitter1's Avatar
Flitter1
Default New RunFlats, New Problem?
Ever since I had two new rear GY Runflats installed on my 98 C5 at the local GY dealer in Lexington, SC, driving it on both the highway and street at normal speeds, I noticed that the rearend is very loose while changing lanes. I noticed that when I turn the wheel slightly that the car is "swaying" into the turn and not "on rails" as it was before the tires were installed. In fact, it feels like something is very loose in the rear of the car. I will take it somewhere, but good advice and help is good to find. I don't trust the dealerships prognosis most of the time. I am running 30PSI all around on my stock coupe and the front GY runflats were replaced just last year w/ @ 5-6 K on them. :confused:
Old Sep 7, 2001 | 11:52 AM
chuckoc's Avatar
chuckoc
Default Re: New RunFlats, New Problem? (Flitter1)
This happened to a friend of mine, he found out that they left the sway bar (I think that is what it was) loose, It is NOT the tires I would bet, before you drive it any further check it yourself or take it somewhere (carefully on tow truck even) It might be something like that, I wish I could recall what it was, But he almost lost it and then he thought it was the Active Handling and bought front tires thinking it was only two new tires, it was not that prob, Something in the suspension is loose Or they bent something jacking the car up? Check it out and give a report back on your findings
Old Sep 7, 2001 | 12:23 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Just another thought... I has happened here to a few... check the direction, make sure they were mounted correctly.. EMT's are directional..some times the obvious is overlooked..
Bill ( Evil-Twin )
Old Sep 7, 2001 | 12:29 PM
chuckster's Avatar
chuckster
Default Re: New RunFlats, New Problem? (Evil-Twin)
Took the words right out of my mouth...I'll bet the tread is facing the wrong direction...
Old Sep 7, 2001 | 02:35 PM
Flitter1's Avatar
Flitter1
Thanks for the Replies
Old Sep 7, 2001 | 02:47 PM
2kbluestreak's Avatar
2kbluestreak
Make sure all your lug nuts are tight.
Old Sep 7, 2001 | 04:28 PM
WEF's 95's Avatar
WEF's 95
Default Re: New RunFlats, New Problem? (2kbluestreak)
Be sure to post the fix.
Old Sep 7, 2001 | 05:34 PM
Flitter1's Avatar
Flitter1
Default Re: New RunFlats, New Problem? (WEF's 95)
Talked to the GY dealer today and found out that they did not use a rack system to lift the car. They used a jack!!!!! So who knows if they screwed something up. I am going tomorrow 9/8 to find a solution to this problem. i will post the fix as soon as completed.
Old Sep 8, 2001 | 08:55 AM
JCR's Avatar
JCR
The tread design (rotational) should not affect handling to the extent you mentioned. The tread grooves are for channeling the water away,and has no effect on dry pavement.
Old Sep 8, 2001 | 10:24 AM
AllVette's Avatar
AllVette
I have been through about 6 sets of GY EMT's on my C5's and I get this every time I put a new set on. You get a lot of compliance from the thicker tread blocks on the new tires. The car feels like it floats. There is a curve I go around on the way home every day that I normally take at 70 MPH with cruise control on. After I get new tires the best I can do is 62 and that brings on the active handling. This is the reason that racing tires are shaved.
Old Sep 8, 2001 | 12:33 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Re: New RunFlats, New Problem? (AllVette)
Mine had the same feeling when one of my rear shocks had gone bad, the car felt as if it was going to come around at times and was worse when hitting dips in the road.
You can unbolt them at the top by removing the two 13mm bolts and see if they are still firm or just fall down.
In my case it was the right rear, it's as good as new since the shock was replaced.
Good luck !
:cheers:
Old Sep 8, 2001 | 03:02 PM
goldman's Avatar
goldman
If all they did was put the tires on... they shouldn't have touched the sway bars, shocks, etc. I'd check imediately for anything loose & get back to them ASAP for a double check/fix.
Old Sep 8, 2001 | 05:43 PM
wwashing's Avatar
wwashing
All new tires feel a little squirmy at first!
Old Sep 8, 2001 | 07:40 PM
Avanti's Avatar
Avanti
Default Re: New RunFlats, New Problem? (wwashing)
JCR, Yes incorrectly installed unidirections DO make that much difference. A friend's WIFE just picked up his Vette with new tires installed at GY dealer, drove 1 block, freaked, and turned around and went back. Two tires had been mounted backwards. Duh!!! She said it was unbelievably squirrelly!
Old Sep 10, 2001 | 12:29 PM
Flitter1's Avatar
Flitter1
Default Re: New RunFlats, New Problem? (Avanti)
Tire problem fixed. It was the torque of the lug nuts! They remounted them correctly and fixed my swaying. Thank god it wasn't anything else, just a little tightening.
Old Sep 10, 2001 | 02:00 PM
willi's Avatar
willi
If the lug nuts were that loose, you might want to check the wheels,
nuts and studs for damage.
Old Sep 10, 2001 | 02:06 PM
ILBob98's Avatar
ILBob98
With the lug nut torque problem, you also have the potential for warped rotors.
To New RunFlats, New Problem?
